Results 1 to 4 of 4
Thread: EC1600
    Dec 2008
    EC1600
    We have a Haas EC1600 with thru the spindle coolant. When using TSC the coolant turns on but the spindle stops and is waiting? The alarm states low TSC coolant?, but the sump is full? does anyone have any ideas?
    Oh yeah the TSC works when there is a tool in the spindle with small feed holes, currently we are trying to use a large insert drill with large feed hoes. Could this be a low pressure feed back to the control??
    Thanks in advance.
    Jan 2012
    what line in program are you putting the m88?
    Feb 2010
    Quote Originally Posted by Bada Bing View Post
    Thanks in advance.
    Yes, the TSC system has a pressure switch; not enough back pressure.
    Jan 2012
    I have run my ec1600 tsc with no tool in spindle with
    no problems. Check your gate filter on coolant tank and also
    check the gage on the tsc filter housing to see if
    that filter is dirty also.
  1. EC1600 Alarm 643 Low Brake Oil A Axis
    By genius in forum Haas Mills
    Last Post: 04-22-2009, 01:34 PM
  2. EC1600 - Renishaw TS27r
    By Ginger_Ninja54 in forum Haas Mills
    Last Post: 02-26-2009, 02:05 PM
