Results 1 to 9 of 9
Thread: Crashed VF3
    Nov 2009
    Crashed VF3
    Hi Guys,
    We have a 1997 VF3 that was crashed pretty hard, Z rapid move and 4" shell mill right into a part. Does a striped down VF3 have a transmission? I was under the impression gear heads only had a transmission and direct drives machines have just a belt to drive the spindle? Could anyone give me advise how recover the machine?
    Thanks in advance,
    Eric
    Gold Member Bloy2004's Avatar
    Oct 2003
    Sturgeon Bay, WI
    Take a good tarp and drape(recover) it over the machine. This is under the assumption that it had previously been covered.
    Other than that, you need to tell us what it doesn't do now that it did before the crash.
    Shoptask rebuild:
    http://www.cnczone.com/forums/showthread.php?t=2139
    Home built gantry router:
    http://www.cnczone.com/forums/showthread.php?t=5049
    Feb 2009
    Id be less worried about the transmission at this point. You probably moved the Z axis at minimum, so now the ATC may not line up, damaged spindle bearings, and possibly the taper. Call a tech in. You'll be money ahead.
    Registered WallyL7's Avatar
    Dec 2008
    Quote Originally Posted by underthetire View Post
    X2. There is no magic recover button for that.
    Tim
    Registered Machineit's Avatar
    Mar 2010
    Unless you have found a problem already, you probably have none. I have see this happen many times and no problem except the part and probably broken inserts.
    Reset the servos and jog up. Remove the tool and home the axis' to see if everything looks okay. Try a tool change to see if it lines up, but should.
    They are not really that fragile and the servos shut down pretty damn fast.
    Tell us all of the dirty details.
    Mike
    Haas VF-2, HA5C, Hardinge CHNC 1, BobCAD V23
    Apr 2010
    Quote Originally Posted by Bloy2004 View Post
    You really went all in with that one...
    Nov 2009
    The machine has no alarms when the spindle is started there is a deep clunking/rattle sound. After removing the head cover noticed there was a gear box under the spindle motor. I removed the spindle drive belt and the spindle turns smooth, free and there seems to be no play.
    Feb 2010
    Quote Originally Posted by Eric MFG View Post
    Hi Guys,
    Do you have a High and Low gear? If yes then you have a gearbox.
    If the spindle moves freely, it most likely is okay. If the gearbox sounds like it has a bunch of rocks in it, then you probably chipped some teeth on the gears.
    Registered KenFoulks's Avatar
    Aug 2010
    Haas Factory Support
    From the Haas Factory Service Team:
    You can run the transmission without the spindle belts to see if you hear the same noise. If you do, then you might need a new transmission.
    Thanks,
    Ken Foulks
    1. Crashed: Milacron 208 Lathe
      By VanFLT in forum Cincinnati CNC
      Last Post: 08-19-2011, 08:05 PM
    2. EC2.3.5 Crashed
      By erlyrisa in forum LinuxCNC (formerly EMC2)
      Last Post: 07-29-2010, 01:50 AM
    3. Need Help!- Crashed Our VF-2 Need help
      By DaOne in forum Haas Mills
      Last Post: 04-20-2009, 03:24 PM
    4. Problem- Crashed 4th axis on a 5025 VMC
      By Cncjunkie in forum Daewoo/Doosan
      Last Post: 04-08-2008, 12:30 PM
    5. SMTC crashed
      By JPMach in forum Haas Mills
      Last Post: 03-16-2006, 08:16 PM
