Results 1 to 3 of 3
Thread: Pipe Thread
    Apr 2003
    Pipe Thread
    I have a 2001 SL-20 Lathe that I have cut a lot of threads on ,but now I have a job that needs a 2" 11 1/2 npt thread and don't know where to get the info on how to program this thread . Thought if anyone could help it would be you guys!! Thanks in advance!
    Moderator HuFlungDung's Avatar
    Mar 2003
    Did you check the haascnc website?
    http://www.haascnc.com/custserv_training.asp#lathe
    I suggest the lathe workbook for you.
    Sep 2005
    canada
    Hopefully this is helpful. I am currently studying cnc programming. I wrote a program for a 1-1/4 11.5 npt and it worked out great. I made some adjustments to suit your 2 11.5 npt So hopefully this is usefull.
    O0001
    (2-11.5 NPT THREAD)
    (HANDTIGHT ENGAGEMENT 5 TURNS)
    (TPI .0625)
    (THREAD HEIGHT .0695)
    N3 (ID TAPER) (TIP 2)
    N300 G00 T202 M42
    N301 G96 S350 M03
    N302 Z0.1
    N303 X2.75 M08
    N304 G71 P305 Q310 D0.025 U-0.01 F0.005
    N305 X3.1
    N306 G01 G41 Z0.
    N307 X3.063
    N308 X2.888 Z-0.085 (CHAMFER)
    N309 X2.831 Z-1. (PIPE TAPER)
    N310 X2.75
    N311 G00 G40 Z0.1 M09
    N312 G28 U0. M05
    N313 G28 W0.
    N314 M01
    N5 (ID THREADING) (PIPE THREAD ID)
    N500 G00 T303
    N501 G97 S300 M03
    N502 Z0.5
    N503 X2.75 M08
    N505 G99 G76 X2.925 Z-1. A60 I0.047 (1.5 X .0625/2) K0.0695 D0.02 F0.0869
    N506 G00 X2.75
    N507 Z0.5 M09
    N508 G28 U0. M05
    N509 G28 W0.
    N510 M01
    N511 M30
