Change the setting for T and H matching. Look up the setting number in the manual.
HI all, My 2003 TM1 has a 10 tool, tool changer, but my control as 15 tool offsets. I would like to have 15 dedicated tools with preset tool length offsets.
Say after the 1st op I switch out tools 6-10 with tools set as 11-15
How do I call up say tool 13, with it's preset tool length offset, without the Haas alarming out?
would the code just be:
T8 M6
G0 G54 G90 Xx.xxx Yx.xxx M3
G43 H13 Zx.xxx M8
Thanks for any help.
Kyle
http://www.kirkcon.com/
Under Setting Graphics, setting 15 is H and T matching. It is normally"ON," just change it to "OFF." Then it will allow you to call a tool number and a H offset that do not match.
I would strongly recommend that you change it back when not used, if you do a lot of manual programming.
Mike
Haas VF-2, HA5C, Hardinge CHNC 1, BobCAD V23
Thanks gents, worked just fine
