I have a part that is first turned on a lathe and has holes drilled around the face of the part at weird angles and a flat milled on the edge of the part. It is a muilti axis lathe/milling machine. Anyway the part is then taken from that machine and put into a 3 axis TR3 Haas where is has surfacing done to both sides. The machine is equiped with a renishaw probe, but we use a dile to ensure the flat is in the machine perfectly straight with the "Y" axis.
My question is:
Can I eye ball putting the part in straight and probe the part so there is some sort of a degree offest?
The program is in G-code and since it is surfacing two concave circles in diferent directions the program is very long, so it would have to be a code that applies to everything, not a code on each line.
Hope this makes sence
LinkBack URL
About LinkBacks
