Results 1 to 7 of 7
Thread: Spindle noise
    Feb 2012
    Spindle noise
    hi, im getting a grinding noise when i run the spindle on the VF4 at low speeds.
    any ideas??
    Registered Machineit's Avatar
    Mar 2010
    Quote Originally Posted by deadjam View Post
    any ideas??
    Does it go away in high gear? If so, it is probably the transmission.
    Mike
    Haas VF-2, HA5C, Hardinge CHNC 1, BobCAD V23
    Feb 2012
    Quote Originally Posted by Machineit View Post
    Mike
    the machine has a gearbox, so you think it might be that?
    Mar 2010
    Yes, that's why I said to put it in high gear and see if the noise goes away.
    Mar 2009
    It could also be a damaged or loose spindle encoder belt. That is a quick and easy thing to check and repair. If that is it you will also have to change PARA 257 for your spindle orientation.
    Mar 2012
    China
    air cooling spindle or water cooling spinlde?
    Mar 2010
    Is this an "academic exercise" or what? How about letting us know the outcome. A simple put it in high gear and see what happens would tell us volumes.
    Hello, anyone there?
    1. Sieg X3 spindle noise
      By brento in forum LittleMachineShop CNC Machines
      Last Post: 07-04-2011, 05:24 AM
    2. Spindle noise
      By fidia in forum Syil Products
      Last Post: 11-28-2010, 07:56 AM
    3. Noise from spindle on Leadwell V-40
      By SRT Mike in forum General Metal Working Machines
      Last Post: 11-24-2008, 11:41 AM
    4. Spindle Noise
      By FXRGUY in forum Daewoo/Doosan
      Last Post: 01-29-2008, 05:20 PM
    5. Way Oil and Spindle Noise
      By ETM Shop in forum Syil Products
      Last Post: 01-28-2007, 10:06 PM
