Page 1 of 2 12 LastLast
Results 1 to 12 of 13
Thread: Coolant passage gaskets leaking on VF2
    Feb 2007
    We had some work done on our VF2SS about 3 months ago. While the tech was gone in the evening, we replaced the original gaskets on the coolant passages through the head that were leaking. As per our tech's advice, we used cork, and spread a layer of permatex on both sides of the cork before putting it back together.
    Here we are, 3 months later, and now the gaskets aren't leaking, they are pouring coolant all over the place! Does anybody know what works?
    Mike
    May 2004
    Attach a photo of the area in question.
    http://www.kirkcon.com/
    Feb 2007
    Here it is...
    Mike
    Attached Thumbnails Attached Thumbnails Coolant passage gaskets leaking on VF2-img_0091.jpg   Coolant passage gaskets leaking on VF2-img_0092.jpg
    Registered Machineit's Avatar
    Mar 2010
    That does happen when you have the coolant running and the valve closed, but you DO need to do that at times.
    Make sure all of the surfaces are totally flat, super CLEAN, and deburred. Use a real good grade of silicone sealant or the equivalent. That stuff will seal anything if used right.
    Make sure there are no burrs on the bolt holes on the plate either and bolt it down securely. Now comes the hard part, follow the directions on the sealer and don't use for at least 24 hours probably. After that, do not close off the coolant valve for a few days.
    If you do that, it will last a long time. If you hurry it, it will fail again soon. Gaskets are fine, but do it the same, let it wait!
    Mike
    Haas VF-2, HA5C, Hardinge CHNC 1, BobCAD V23
    May 2004
    Quote Originally Posted by Machineit View Post
    Mike
    +1
    Mar 2010
    Quote Originally Posted by txcncman View Post
    +1
    Oh come on, I got one right!?!?!?!?!
    Just so you know, I speak from much experience.
    This particular machine has less surface area than most older machines, which is good. The older ones were about 10 x 8 inch or about 80 square inches and at maybe 10 to 15 lbs/square inch it was a lot of pressure to bow or deflect the plate.
    Just clean it like surgery and let it set up.
    Mike
    Jul 2005
    Sikaflex is what I have used in the past. No problems afterwards. Clean it to the point you can eat off it. That is the most important thing. Any oil and it wont stick.
    Feb 2007
    Mike
    We gave it a try. I guess time will tell if we got it clean enough. The instructions on the tube said to wait 15 to 16 hours. So we'll give it a try about lunch time tomorrow.
    Thank you very much for the input!
    Mike
    Feb 2007
    Quote Originally Posted by DaOne View Post
    We will probably go that route if what we did doesn't work out. We were just afraid to because the plates will probably never come off again using Sikaflex. That is some strong stuff.
    Thank you for the input!
    Mike
    Jul 2005
    Quote Originally Posted by gizmo_454 View Post
    Mike
    I use a good per-filter so I hope that is the case. It was a real pain getting it sealed up. I tried silicone... It lasted about a week. If I ever need it off I have an air chisel handy
    Feb 2010
    Mike
    That is a good plan. Most places get to impatient to let it set up properly. I have alway had good luck using the Loctite Ultra Black Gasket Maker Silicone. As mentioned though, proper prep and proper dry time are critical.
    Sikaflex is the best but it can be a bear to deal with sometimes. Hopefully your fix will hold for a good long time.
    Good Luck!
    Sep 2011
    We have to clean the heads out every other year and always use new gaskets from Haas. Never have a problem with leaks. The gasket for the pic shown is a 57-0130A and is only around $4.00 ea. The machine is ready to run right away.
  • Page 1 of 2 12 LastLast
    1. Coolant leaking into base
      By Machining in forum Haas Mills
      Last Post: 11-11-2011, 08:20 PM
    2. Coolant Tank Leaking
      By mekp21 in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 07-15-2010, 01:05 PM
    3. coolant tank lid leaking
      By R.DesJardin in forum Tormach Personal CNC Mill
      Last Post: 01-29-2009, 09:18 AM
    4. Leaking coolant reservoir
      By JTulley in forum Tormach Personal CNC Mill
      Last Post: 08-03-2008, 09:51 AM
    5. Problem- Haas TM2 Leaking Coolant
      By Chris Swier in forum Haas Mills
      Last Post: 06-20-2008, 10:57 PM
