Results 1 to 5 of 5
Thread: Difference between VM3 & VF3?
    Dec 2008
    Are there any structural differences between a VM3 and VF3? I have already looked at the website and know the options are different but is there more meat to a VM3?
    Registered WallyL7's Avatar
    Dec 2008
    The VM's have 26 inches of -y- travel...and different ball screws. (both of those aren't options)
    Other than that I'd say they are the same machine...only different.
    Tim
    Apr 2004
    O.C. Californa
    The Vm is 30 hp has a different ball screw, a different table, different casting the casting is actually the casting of a VF-5.
    The VF-3 and VM-3 are Different.
    Dec 2008
    I think with the additional 26" on -y- it was obvious you are going to get more meat (whatever that means). Looks like it weighs about 1500 pounds more.
    From my memory our VF8 couldn't take more of a cut than our VF2 could given similar/same setup. The mold machine has way different features to accommodate .....well.....more "mold" type operations.
    My previous post was more tongue in cheek. I figured you saw that one has more thrust/hp/bigger table/etc.
    Tim
    Registered KenFoulks's Avatar
    Aug 2010
    Haas Factory Support
    Quote Originally Posted by wcbob View Post
    +1 VM-3 is better suited for 3D work. If you are looking to purchase a new VMC, consider the VM series for your 3D applications.
    Thanks,
    Ken Foulks
    1. difference between a 6m and 6m b
      By beekeeper in forum Fanuc
      Last Post: 08-03-2010, 06:50 PM
    2. Need Help!- Difference between 2D NC and 2.5D NC
      By Pols in forum General CAM Discussion
      Last Post: 10-14-2008, 08:30 AM
    3. Difference between 320 and 340?
      By amasters in forum Gecko Drives
      Last Post: 05-24-2006, 06:46 PM
    4. What is the difference?
      By Hack in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 10-09-2005, 10:46 AM
    5. What's the difference?
      By Hack in forum General Metal Working Machines
      Last Post: 09-05-2005, 08:35 PM
