At work my boss has an sl-10 and we were trying to figure out if we can program the chuck to only open to a certain dia so we can use the bar puller without the part falling into the opening. Does anyone have any experience with this or any idea how to attempt doing this or if its even possible???
James
Give some more details, such as actual part diameter and length.
http://www.kirkcon.com/
machine a metal ring to diameter that suits then slip it over the jaws and this will stop them opening to far.
Philip
what machine do you have
Why not use Spindle Orientation? Just orient the spindle so that one of the 3 jaws is on the bottom? Then the bar cannot fall in between them. It is sitting on one. Assuming you are using jaws that were machined round for the bar and not using hard jaws. Even if you don't have the Spindle Orientation option turned on, you can still use it...sort of. The option allows you to orient to specific angles. Without it, you cannot choose the angle. It just goes to "0". Of course, this will only work if the chuck is bolted on in the right place for one of the jaws to be down at "0".
Good luck...
Mike![]()
Just position the jaws so that with the chuck fully open there is just enough clearance for the bar to slide. The jaw adjustment is about 1/16" so the maximum clearance you can around the bar is 1/16" or less, and this should be small enough that the bar cannot fall down between two jaws.
The beaten path, is exclusively for beaten men.
But for your information the jaw serrations are 1.5 mm apart(.059") basically the same dimensions that are the jaw stroke, so pretty easy to figure out.
Robert
Does this help?
sl10 safety window
