Page 1 of 2 12 LastLast
Results 1 to 12 of 13
Thread: Aligning Two Vises
    Apr 2009
    Aligning Two Vises
    I set up one vise and have it within 0.001 all the across. I'm trying to now set up an identical vise about a foot to the left of it to the exact same measurments. I can set it up and get the right side of the vise equal to the other vise, but as soon as I try to dial in the left side everything gets screwed up. It's racking my brain how much harder it is for me to calibrate a single vise, but to calibrate one off the other seems near impossible (I know it's not, just saying).
    Any tips for this? Sorry if this is a total noob question.
    Feb 2009
    Soft jaws, rough them in then just cut them.
    Apr 2009
    Oh sweet baby jesus. Darwin award of the day:
    The dial indicator mount some how came loose, so everytime I was tapping the vice, it was rotating the indicator.
    Embarassing... yet relieving....
    Registered KenFoulks's Avatar
    Aug 2010
    1. You can use a piece of material (tighten in right vice, then push the left vice against the material)
    2. You can see if your vice has the ability to use pins for alignment
    3. You can use soft jaws as underthetire recommended
    4. You can trig out the movement, based on the right bolt as the pivot point
    5. You can make a fixture that locates on a certain feature.
    Thanks,
    Ken Foulks
    May 2004
    Easiest way, if you have a ground piece of bar stock, is clamp the bar stock in both vises and then indicate the bar stock and tighten the hold down bolts.
    http://www.kirkcon.com/
    Apr 2008
    If you can't indicate two, three or even four vises in line within .0005 of each other, perhaps you should think of another line of work to get into...
  7. #7
    May 2008
    Quote Originally Posted by Boone View Post
    What a great reply, hope it will help somebody...
    Jeff
  8. #8
    Registered Machineit's Avatar
    Mar 2010
    Quote Originally Posted by jeffrey001 View Post
    Jeff
    Thanks Jeff,
    I had some to say that was less kind, but held my typing finger.
    Haas VF-2, HA5C, Hardinge CHNC 1, BobCAD V23
  9. #9
    Registered l u k e's Avatar
    Apr 2005
    Quote Originally Posted by Machineit View Post
    Thanks Jeff,
    lol, I deleted my reply before I hit Submit.
    2008 Haas VF2
    OneCNC XR4
  10. #10
    Jan 2007
    You know boone has a point , if you cant do that How the heck you going to inspect your parts. Sometimes common sence has to come into play.
  11. #11
    May 2008
    clement1292 said that it was a noob question...
    IMHO, that's why forum exist, someone with less experience asking for help from members having more experience.
    Just my 2 cents.
    Jeff
  12. #12
    Mar 2010
    I think everyone missed the post where he found his indicator had come loose and fixed the problem!?!?!?!?!?
  1. vises
    By 2ferrous in forum Dyna Mechtronics
    Last Post: 01-18-2011, 10:28 PM
  2. Chick Vises
    By extanker59 in forum Haas Mills
    Last Post: 04-18-2009, 01:52 AM
  3. Vises on a Taig Bed
    By 5artist5 in forum Taig Mills & Lathes
    Last Post: 04-09-2009, 05:31 PM
  4. Routers and Vises
    By ssozonoff in forum Work Fixtures and Hold-Down Solutions
    Last Post: 01-16-2009, 08:10 AM
  5. Machine Vises
    By stedgar in forum General Metal Working Machines
    Last Post: 06-08-2008, 11:15 AM
