Results 1 to 7 of 7
Thread: Skip line in graphics only??????
    Mar 2010
    Question Skip line in graphics only??????
    Is there a way that I can have a line in a program that basically block deletes or skips ONLY when the program is ran in graphics? What I am trying to do is I have a cycle counter at the end of the program to count how many parts I have made, and I dont want it to count when the program is ran in graphics(obviously, because no parts are made in graphics ).
    It would be nice if it were something simple like a system macro set itself to 0 or 1 when ran in graphics and I could use an IF statement for my counter line.
    May 2004
    How many times are you running the program in graphics mode?
    http://www.kirkcon.com/
    Feb 2010
    Quote Originally Posted by DruMor View Post
    Nothing of the sort to my knowledge
    Registered WallyL7's Avatar
    Dec 2008
    I'm not sure why you would run graphics ever after you start running parts.
    If you are changing the program randomly then...well...um k.
    Tim
    Mar 2010
    Yes, I do make changes after I start running parts. I have 1000 pieces total to run, but 4 variations of this part make up the 1000 pieces. I run 250, then change a block delete and a macro variable, run 250 more parts, change B/D and a variable again and continue. After I make my changes, I like to run it in graphics and make sure I didnt accidently fat finger something and enter a value wrong.
    I wanted to make it count cycles so it could alert the operator when a changeover to the next part version is coming to make a seamless transition from one version to the other. The program has 3 stations, the first is the same for all 1000 parts, the 2nd is different for each of the 4 variations, and the 3rd station has to match the 2nd, so several times during the total run I have to shut off/turn on and change the 2nd and 3rd station and I just like to double check in graphics before I let 'er rip after changes.
    May 2004
    Sounds like you need to do some more work on the macro/program/sub program side of things to eliminate your mistakes in keying in the different information.
    Registered KenFoulks's Avatar
    Aug 2010
    Haas Factory Support
    The graphics mode does not properly interpret timers, so you can utilize code like this, from the Renishaw probing macro:
    G103 P1
    G04 P1
    G04 P1
    G04 P1
    G04 P1
    G04 P1
    G04 P1
    #3001= 0
    G04 P250
    G04 P1
    G04 P1
    G04 P1
    G04 P1
    G04 P1
    G04 P1
    IF [ #3001 LT 200 ] GOTO999
    Thanks,
    Ken Foulks
    1. no line number in comment line in mpos
      By MSFAB in forum Surfcam
      Last Post: 02-13-2012, 05:51 PM
    2. Skip Signal
      By derekBPcnc in forum Fanuc
      Last Post: 11-17-2011, 01:43 AM
    3. New skip in the house
      By latheboy in forum CNCzone Club House
      Last Post: 08-20-2011, 12:30 AM
    4. Need Help!- way to see the g code comands visualized line by line in Bobcad?
      By 777funk in forum BobCad-Cam
      Last Post: 04-07-2011, 08:48 PM
    5. Replies: 0
      Last Post: 01-13-2011, 09:07 PM
