Um... Close the door? Turn on door close overide in settings? Be careful with that one, as the machine will then run with the door open. Meaning, you can leave the door open and the machine runs when cycle start is pushed.
I am not sure why you get an A axis fault with that parameter changed. A good reason to not mess with PARAMETERS. Only mess with SETTINGS when needed.
Mike
LinkBack URL
About LinkBacks
