Thank you to everyone who has replied..
Today i had some time to have a play with the machine and run through some of the sudgestions made here.
The tool setup issue has mostly been sorted out with the exception that for some reason the tool change won't work in jog mode. Is there a setting that allows this? If i could get the machine to change tools (by a T#, ATC FWD) in Jog mode that would solve it completly. :-)
As for the work offsets, i did try some of the sudgested methods but it seams that i am back where i started. I managed to get it to set a value other than zero on the operator jog to try and negate lifting and moving when using an edg finder. It does work but then you need to lift and jog back to zero anyway in order to set the G54 work offset, which kinda defeats the purpose.. In fact any time when using the operator jog you must jog back to X0,Y0 to then set the work offsets.
I also played arround with setting the work offsets directly in the offsets page. Again it does work, but you are effectivly working in machine coordinates, not work coordinates. The readout down the right hand side of the screen does show the current work offset position but it does not update when you make a change to the offset it's self (Ie add or subtract from it), you must press reset to update the readout. This of course stops the spindle and it must then be restarted. It does update if you just press "part zero set".
I guess at the end of the day i'm just going to have to suck it up, stick with what i know will work, and get on with it..
Thanks again
Cheers
Leeroy
