As far as I know, not possible. Why would you want to? Do you think you are going to save electricity? Keep the monitor "fresh like new"?
Is there a way on the VF series to get the monitor display to shut off while a program is running?
I know what setting 199 and the screen saver do but that is only when the machine is idle. Let's say you have a 50 minute program and you want to have the display go dark a minute after hitting cycle start and stay dark unless an alarm pops up or you hit a button on the controller to bring it back up. How would one achieve this, if it is even possible?
http://www.kirkcon.com/
If there is not a built in function for this, it would be very easy to add a power switch to the monitor power.
New machines have this feature but not the older ones.
Could be set up with a new relay and an M code function, but it's a little bit of wiring.
Mike
Haas VF-2, HA5C, Hardinge CHNC 1, BobCAD V23
M76 is the closest feature to this request:
M76 Control Display Inactive / M77 Control Display Active
These codes are used to disable and enable the screen display. This M-Code is useful during the running of a large complicated program as refreshing the screen takes processing power that otherwise may be necessary to command the moves of the machine.
Thanks,
Ken Foulks
Thanks! I will give this a try later today.
For those with controls featuring setting 100, this will turn on the screen saver after the programmed time limit.
Thanks,
Ken Foulks
