| I have the high volume pump & run alum, the chips stop up the coolant lines so it almost stops. I pull them off & they are plugged with chips. What do you owners of mini mills do to stop this? |
If you are unlucky you may find you have to take the cover off the spindle assembly to get at a coolant line connection inside to remove the hose and clean out chips that will not blow out using air. |
like mad. Why did they set it up with only 1/4" locklines? Do you have the # on the cartridge filter, home Depot ain't to smart. So you put it between the pump output & the line that goes up to the spindle. Only way it would work. How often do you have to change/clean the filter? Thanks for your help. I run very small parts @ slow feeds & chips are very small. |
It is a standard houshold sediment filter; G.E. Model GXWH04F and includes a mounting bracket, wrench for the housing and a couple of filters. The filters last for at least six months. They are cheap and easy to replace whether they are clogged or not. |
| Same thing here..but we use a Teel strainer from Granger on all the machines..clean them about once a week..
Can you tell me what filters you use? They have many different types that fit this unit. Only way I can run now is with 3 lines wide open or they will plug up. And with that HV pump you can't see anything at all with that much coolant pumping. Thanks again. |
Hi WMS, Thanks for the information on the TEEL 2P581 Strainer. I stopped by Grainger this morning and picked one up for my machine. I have attached a few pictures for anyone that is interested. John |
| I've got you all beaten. ![]() I had a $10 coupon for Lowes that expired yesterday so I had to use it. I bought the 'large house' filter system: the larger 4" diameter cartridge style and the clear case ($60). I just couldn't get over the idea that the smaller cartridge might restrict the flow of the washdown hose. I took the plunge and bought the big one. Now I've got to find a place to mount it. The reason I started this quest was the sprinkling of fines that I would find all over the table after washing everything down over and over. This should fix it.
__________________ Greg |
