Results 1 to 5 of 5
Thread: Haas Diameter offset and spindle speed parameters
    Jan 2012
    Greetings all! My pops and I were playing with his new toy, a TM1, and found out that the "Diameter offset" parameter is set to read a Diameter. While I understand why this is done this way and why people prefer it... we're old school and used to all of our Mori's at the big shop. How do we change the parameter so that we enter the radius of the tool on the offset page instead of the diameter.
    Also, where is the parameter to change the Max RPM of the spindle, we have the code to change it but I don't know where to enter it.
    Thanks in advance.
    May 2010
    re: radius vs diameter
    Push the settings button, the page down until you see it. It's likely also in the manual.Get the cursor to the setting. IIRC you just use the right button arrow to toggle it, then press the "write" button to accept the new setting.
    May 2004
    From the Haas manual:
    Cutter compensation is a method of shifting the tool path so that the actual
    centerline of the tool is moved to either the left or right of the programmed path.
    Normally cutter compensation is programmed to shift the tool in order to control
    feature size. The offset display is used to enter the amount that the tool is to be
    shifted. The offset can be entered as either a diameter or radius value, depending
    on setting 40, for both the geometry and wear values. If diameter is specified,
    the shift amount is half of the value entered. The effective offset values
    are the sum of the geometry and wear values. Cutter compensation is only
    available in the X-axis and the Y-axis for 2D machining (G17). For 3D machining,
    cutter compensation is available in the X-axis, Y-axis and Z-axis (G141).
    All I had to do it take the time to look. So much information in a manual. Amazing.
    http://www.kirkcon.com/
    Oct 2010
    u.s.a
    try setting 40
    Jan 2012
    Thanks guys. I'll check setting 40. I obviously overlooked that when scrolling through the settings page.
    1. Need Help!- Can't find diameter offset screen!! - Hitachi-Seiki VK45 w/Seicos Mk2 control
      By laka in forum General Metal Working Machines
      Last Post: 12-04-2010, 12:10 PM
    2. Need Help!- Parameters 18i lathe radius to diameter
      By VIDE in forum Fanuc
      Last Post: 08-18-2010, 08:11 AM
    3. Are lathe offset values on radius or diameter?
      By sinha_nsit in forum Fanuc
      Last Post: 11-06-2009, 09:46 AM
    4. Diameter offset
      By qmas99 in forum SolidCam
      Last Post: 03-24-2008, 08:31 PM
    5. Newbie- Hi all, Tool diameter offset question.
      By chad123 in forum Haas Mills
      Last Post: 03-14-2008, 03:02 AM
