Results 1 to 3 of 3
Thread: VQC program templates...necessary?
    Registered MauserBob's Avatar
    Feb 2006
    Good morning, folks.
    I apologize in advance for the duplicate thread ( posted in the VQC board as well ), but this board sees more traffic and I'm kinda in a time crunch so I thought I'd post it here too.
    We have a VF-3 in our shop that has 3 VQC programs in memory. We bought the machine new in December '05 and have never used the VQC progs in the 6 years we've had the machine. We are not DNC-capable so we keep as many of our regularly-running part progs stored in machine memory but recently we found ourselves with a massive program (677 kb) that will not fit in the machine without stripping the memory down to bare bones and even then I'm still 120k shy of what I need. We used to have just over 100 progs stored in memory which left only 19% free space but now we're literally down to the bottom of the barrel with only 10 or so still stored, including spindle warmup, etc, and surprisingly the machine says that we've only got 54% memory free now. What we've got left loaded in there probably doesn't add up to 20 k. This is alarming to me, so, basically I decided to take a look at the VQC progs and discovered that they're enormous, even as basic templates. The first one ( #9997 ) is 137 k, the second one ( #9999 ) is 28 k and the third one ( #11111 ) is 145 k which all adds up to 310 k. Getting rid of those progs would solve my problem at a stroke but I'm reluctant to do so since the rule of thumb (at least as I was taught) is that you leave 9000-range progs alone since they're usually important machine-parameter progs like tool-change subroutines and whatnot. I did download them into my PC for backup in case I can dump them but I won't dump 'em until and if I know that I can do so safely.
    Sorry for the verbosity...any thoughts, anyone? Can I get rid of those progs if we never use them, or should I leave them alone? Here are the progs, listed by header name, in case it helps:
    1.) O09997
    (HAAS VQC Mill, English, Inch, V1.4A)
    (11/14/01)
    2.) O09999
    (HAAS Mill Menu QC ver. 2.8)
    (07/14/01)
    3.) O11111
    (11/14/01)
    Thank you in advance, guys. And by the by, I realize that it seems as if we have two of the same prog loaded ( 9997 and 11111 ), but I have no idea why that is since, as I said earlier, we've never used them. They came pre-loaded from the HFO, and I do believe that our machine was the floor-demo at our local machinery house so that may explain it.
    Rob.
    Feb 2010
    Unless you use the VQC editor the machine will run fine without them. You can leave them out permanently if you like and keep them on your PC just in case you change your mind.
    BTW, you do have duplicates of the one program so you can delete the O11111.
    Feb 2006
    Thank you, Haastec. They have been dumped and I gained a ton of useful room.
    Appreciate the feedback.
    Rob.
  1. templates
    By ant818 in forum Vectric
    Last Post: 11-22-2011, 11:38 AM
  2. CAM Templates
    By Dougal in forum CamBam
    Last Post: 11-18-2010, 08:12 PM
  3. Need Help!- templates
    By suzukirmz in forum Solidworks
    Last Post: 11-05-2009, 09:25 PM
  4. Templates in UG NX5 (or 4)
    By Cammotion in forum General CAM Discussion
    Last Post: 11-02-2007, 01:17 AM
