Results 1 to 6 of 6
Thread: anyone have the minimill test program?
    Oct 2010
    England
    after getting a temporary fault with the motor on my sl10 lathe i would now like to run a daily test program on my machines which uses all the motors and doesnt just warm the spindle. The machine had a test program when we bought it but i accidently deleted it from the machine.
    Nov 2006
    You could write a quick program that travels the table to its full dimensions using machine coordinates (G53). You'll have to jog the machine to it's maximum work envelope then write down the numbers, then put them into a quick program.
    Here's an example (if you ignore the first part with the multiple toolchanges) http://www.youtube.com/watch?v=IZQ3NmCAIE0]Haas Super Minimill Toolchange/rapid demo - YouTube
    May 2004
    Quote Originally Posted by garylb View Post
    You want a minimill test program for an sl10 lathe? After you accidentally deleted it? Are you sure you are qualified to operate this equipment?
    How about a "warm up" program for an SL10 lathe?
    Maybe start with:
    O00001 (WARM UP PROGRAM)
    G0 G20 G40 G80 G90
    G53 X0.
    G53 Z0.
    T100
    G97 S200 M3
    G1 W-5. F0.1
    G1 U-5.
    G4 P10.
    G1 U5.
    G1 W5.
    G4 P10.
    M5
    G53 X0.
    G53 Z0.
    T200
    G97 S400 M4
    G1 W-5. F0.05
    G1 U-5.
    G4 P10.
    G1 U5.
    G1 W5.
    G4 P10.
    M5
    G53 X0.
    G53 Z0.
    T300
    G97 S600 M3
    G1 W-5. F0.025
    G1 U-5.
    G4 P10.
    G1 U5.
    G1 W5.
    G4 P10.
    M5
    G53 X0.
    G53 Z0.
    T400
    G97 S800 M4
    G1 W-5. F0.025
    G1 U-5.
    G4 P10.
    G1 U5.
    G1 W5.
    G4 P10.
    M5
    G53 X0.
    G53 Z0.
    T500
    G97 S1000 M3
    G1 W-5. F0.025
    G1 U-5.
    G4 P10.
    G1 U5.
    G1 W5.
    G4 P10.
    M5
    (ABOVE PATTERN CAN BE REPEATED)
    G0 G53 X0.
    G0 G53 Z0.
    M30
    http://www.kirkcon.com/
    Oct 2010
    England
    [QUOTE=txcncman;1056078]You want a minimill test program for an sl10 lathe? After you accidentally deleted it? Are you sure you are qualified to operate this equipment?
    No i need a test program for my mini mill as per title of the thread. I have been running my haas machines for nearly 5 years now so yes i think im qualified to operate them. The memory on the mini mill was full so i was deleting them off but was doing it too fast and accidently pressed delete all. Its easily done and doesnt mean im unqualified to use the machine
    May 2004
    Well...use the above example and write a warm up program for your mill then. Should only take about 10-15 minutes.
    Nov 2007
    australia
    this it what i use on our tm2.
    cycles all axis and ramps up the rpm and feed
    G126 is set at about the center of travel in the X/Y movement
    O99990
    (Warm Spin/Table NO TOOL)
    (18MIN)
    G126 G90
    S500 M03 F1500.
    M97 P100 L3
    S1000 M03 F3000.
    M97 P100 L3
    S1750 M03 F5000.
    M97 P100 L3
    S2500 M03
    M97 P100 L4
    S3500 M03
    M97 P100 L5
    S1500 M03 F2500.
    M97 P100 L3
    G01 X0 Y0 Z0 F5000. M05
    G54 G90
    M30
    N100
    G01 X350. Y180. Z0.
    Y-160. Z-300.
    X-350. Y180. Z0.
    Y-160. Z-300.
    M99
    (use at own risk! travel distance is for a TM2)
    HAAS TM-2
    Mastercam X4/X5 - Level 3 - Solids @ work / HLE @ home
    1. Moving a MiniMill
      By Geof in forum Haas Mills
      Last Post: 03-07-2013, 11:06 PM
    2. This is a test thread in the test forum
      By adam.faris in forum Test Forum
      Last Post: 10-27-2008, 12:21 AM
    3. Cutting speed test program
      By isubsmith in forum Torchmate
      Last Post: 05-14-2008, 06:40 PM
    4. Replies: 6
      Last Post: 05-29-2006, 11:12 AM
    5. Stepper motor test program?
      By starCNC in forum General CAM Discussion
      Last Post: 06-02-2004, 05:37 PM
