What direction is the y-axis trying to move when you home it?
If it is moving toward the front of the machine, the switch is probably sticking. Remove the covers and clean it with WD-40, contact cleaner, etc.
If it is moving to the rear, then perhaps it is not working at all or is not getting tripped. Again, remove the covers and see what is goin on.
Post back what you find and good luck!
LinkBack URL
About LinkBacks
