Results 1 to 7 of 7
Thread: Rigid tapping
    Dec 2008
    Rigid tapping
    Does anyone know if the tap cycle can be changed on a VF-5 Haas so the tap feeds in and out at the same spindle speed, looks like the spindle speed is doubled on the reverse cycle.
    Dec 2008
    Quote Originally Posted by Bada Bing View Post
    There is a setting in the parameters of your machine. Probably on the same page as repeat rigid tap. Set it to 1 and it will be the same as when it went in.
    Tim
    Dec 2008
    Quick Reverse Out of a G84 Rigid Tapping Cycle.
    This rigid tapping feature has the tap exit faster than it entered. A J code on
    the G84 line commands this, for example, J2 retracts twice as fast, J3 retracts
    three times as fast, etc. up to J9. The J code must be specified in each block.
    Setting 130 - Tap Retract Speed
    This setting affects the retract speed during a tapping cycle (The mill must have
    the Rigid Tapping option). Entering a value, such as 2, will command the mill
    to retract the tap twice as fast as it went in. If the value is 3, it will retract three
    times as fast. A value of 0 or 1 will have no affect on the retract speed. (Range
    0-4)
    Entering a value of 2, is the equivalent of using a J code of 2 for G84 (Tapping
    canned
    Jul 2005
    Setting 130 RIGID-TAP RETRACT MULTI set it to 0 or 1.
    If you specify a a J value in the G84 line it will override whatever Setting 130 does. J1 retracts at the same sped as entry, J2 twice as fast, J3 three times as fast, etc.
    Dec 2008
    Quote Originally Posted by Geof View Post
    Hah Geof I beat you to it! Slowly learning
    Jul 2005
    It is my hunt and peck typing that holds me back.
    Dec 2008
    Thanks to all!
    1. Replies: 13
      Last Post: 07-03-2009, 07:43 PM
    2. What exactly is Rigid tapping? Why people always ask does it do rigid tapping?
      By cjchands in forum General Metalwork Discussion
      Last Post: 12-19-2008, 09:19 AM
    3. Tapping head or rigid tapping
      By Gregory_C in forum Syil Products
      Last Post: 10-18-2008, 01:49 AM
    4. Need Help!- Rigid tapping TL 1
      By Peter Gibbs in forum Haas Lathes
      Last Post: 09-06-2008, 07:04 PM
    5. Rigid tapping or tapping head
      By wildcat in forum Industrial Hobbies (Support forum)
      Last Post: 09-24-2006, 01:08 PM
