So you are saying that when after you home the machine, set your work offset and run something that your x position is off .007" - .008"?
Is it back lash or just a positioning error?
Since you mentioned this started after replacing the motor, have you double checked to make sure that all of your motor couplings and ball screw nuts are tight?
LinkBack URL
About LinkBacks
