Results 1 to 4 of 4
Thread: Haas VF6/50 Alarm 961
    Mar 2009
    Has anyone ever had to deal with this alarm:
    961 FLOPPY OFFSET NOT FOUND - This alarm is generated because FNC has lost the offset placemark it needs to correctly advance program. Try to reload program.
    We have never seen this one and will come up at random times when running. We can reset and start running tool paths again.
    Thanks for the help!
    Brian
    Registered KenFoulks's Avatar
    Aug 2010
    Are you using FNC? Does it happen when you aren't?
    What is your software version?
    Thanks,
    Ken Foulks
    Mar 2009
    Quote Originally Posted by KenFoulks View Post
    Yes we are running FNC and it does not happen in DNC. Software version M1609B.
    Sorry for the delayed response I have been swamped! Thank you for the reply.
    Brian
    Aug 2011
    Can you find out the e-net card version, you can look at this on 2nd page of diagnostics , underneath the tool change counter, you will see a FV 12..xxx 13..xxx version.
    How large are the files? do you run lots of sub programs?
    Does the problem occur during sub program calls outs? G65 or M98
  1. ALARM shuttle drawbar alarm haas
    By timmydabull in forum Haas Mills
    Last Post: 02-18-2013, 01:47 PM
  2. Haas VF 3 Alarm 246
    By KartPilot74 in forum Haas Mills
    Last Post: 10-28-2010, 12:29 PM
  3. Need Help!- HAAS VF8 ALARM 971
    By Supafly in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 01-07-2010, 06:02 PM
  4. haas vf-0 alarm 160
    By turboboy in forum Haas Mills
    Last Post: 11-15-2009, 06:59 PM
  5. haas 117 alarm
    By performancerhin in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 06-21-2009, 01:03 PM
