Results 1 to 3 of 3
Thread: Using Probe with Multiple Offsets
    Jun 2006
    I'm using the probe to find the location of a hole. There are 3 features that use the same hole as a datum but they all have different critical Z depths. What I'm doing now is probing the hole three times using G55 G56 G57 work offsets. Then I'm going to each pad and doing a Z depth probe. All this is programmed in to limit operator involvement. Is there anyway in the program that I can avoid probing the hole the extra two times. Maybe a code to take it's current position and inputs it into G56 and G57?
    Apr 2005
    Paradise, Ca, USA
    Probe your G54 bore, then:
    G103 P1
    #5241=#5221 (G55 X = G54 X)
    #5242=#5222 (G55 Y = G54 Y)
    #5261=#5221 (G56 X = G54 X)
    #5262=#5222 (G56 Y = G54 Y)
    G103
    Continue on to probing your three Z depths, then the main program.
    Attached is the OMP40 manual, assuming that's what you're using.
    EDIT: Holy hell did I screw that up! I read your post to have G54, G55 and G56. Whoops. Just alter the variables used with what you find in your machine manual.
    Attached Thumbnails Attached Thumbnails Using Probe with Multiple Offsets-omp40_manual.pdf
    Jun 2006
    Thanks a lot man. I knew there had to be a better way. I'll give it a try on Monday and I'll let you know how things went.
  1. Using multiple work offsets in MC
    By Crashmaster in forum Mastercam
    Last Post: 08-25-2010, 11:18 AM
  2. programming multiple offsets
    By hoganj in forum CamWorks
    Last Post: 07-30-2009, 11:59 AM
  3. Multiple offsets
    By Tinker Simpleto in forum Haas Mills
    Last Post: 12-04-2008, 08:01 PM
  4. Multiple Work Offsets X3
    By timmydabull in forum Mastercam
    Last Post: 08-28-2008, 01:54 PM
  5. Need Help!- Multiple Work Offsets
    By PinMan in forum BobCad-Cam
    Last Post: 06-06-2008, 05:41 PM
