Is Setting 57 = 1? This should only cause Exact Stop when using a canned cycle.
Also, check Setting 85 (Max Corner Rounding). Make sure it is not set to 0. It should be set to 0.025 inches.
I'm from Argentina, I have a haas tm1 to buy used.
I can not get her out of the way "exact stop".
I would like to hear any suggestions.
thank you very much
Dcoupar
First of all I want to thank you for your answer.
I have dealt with the setting 57 and the machine does not change,but did not know about setting 85 ,will try with this parameter, but in my case should use millimeter values
