Results 1 to 7 of 7
Thread: Connecting HAAS to computer
    Nov 2011
    Hello,
    I need some help setting up my computer to my Haas machine. The haas is a 1990 VF1 and i just bought a brand new hp laptop. I have a usb cable coming from the laptop going into the 25 pin rs-232 on the side of the machine. I am using codeshark as the software but when i try to send a program to the machine, the haas doesnt recognize that its connected to a computer. A comport should come up like the machines at school but i get nothing. I have talk to a couple people and they say the cable i have is not really set up for cnc machines...more for just printers. I have mastercam and i am ready to start doing some *****in parts but cant connect my laptop to the machine. Any help will be greatly appreciated!!
    Feb 2009
    You may need to pick up a null modem adapter. All my USB converters for my laptops are USB to 9 pin, then a cable from there to the machine. Sounds like you may have bought a parallel printer cable, not a serial cable.
    Nov 2011
    O yeah I do have the null modem. So coming from the laptop I should have USB to 9 pin, 9pin to 25 pin, 25 pin into null modem, and then null modem into the haas? Does the quality of cable have anything to do with not getting a connection?
    Registered KevinWilkins's Avatar
    Feb 2005
    Germany
    Get the freeware progam offered by OneCNC, I think it's called NCdirect.
    It works like a charm!
    www.wilkins-knives.com
    Aug 2008
    serial port
    a rs-232 serial port connected laptop to cnc does not show the laptop as a harddrive.
    using file transfer software like the free and open source
    EdytorNC | Free software downloads at SourceForge.net
    with communication parameters properly set like 4800, 7,e,1 and no flow control or setting to what ever the Hass manual (or a particular machine) says to use.
    then the cnc machine must be put in a mode for receiving a file by rs-232 serial port (listening or receiving mode) , usually file needs to be given a name first. then laptop sends file and it is in CNC memory only, it needs saving to cnc harddrive or floppy disc if desired.
    for sending to laptop, laptop is put in rs-232 listening mode (receiving mode) and the cnc send or stores to rs-232 serial cable. file shows up on laptop software like edytornc displayed and needs file name and saving to harddrive if wanted.
    so rs-232 serial cable file transfer requires naming files and putting in send and receive mode and saving from display / memory to hardrive or floppy disc or usb
    Feb 2007
    Call your local HFO and they will give you a part number for the correct cable to run from the laptop to the machine. They can be purchased from a third party for reasonable prices, depending on the length of cable you need.
    I personally made my own. Using a 9 pin serial to 25 pin serial cable, a 25 pin to 25 pin cable, and a manual switch box in between. Following the Haas operator's manual, I used an Ohm meter to trace the connections from the pins on the 9 pin end that connects to the laptop to the 25 pin that connects to the machine. I then opened up the box and swapped the lines inside so everything is routed correctly. No cutting of the cables outside. Everything is neat and tidy.
    I found that using the switch box is nice. I can use the same setup for up to 4 different brands of machines using 4 different wiring setups. Just flip the switch to the appropriate location, move the cable to that port, hook it up to the machine, and load programs. I currently have mine setup for both Haas and Citizen machines. Works great!
    Mike
  7. #7
    Nov 2011
    Hopefully thing are working well for you. I ran into a problem using a USB-Serial converter to connect to a PLC from a new HP laptop running Windows 7 64-bit. Here is the issue in case you run into it-
    Windows 7 has a strange behavior when COM ports are assigned to USB devices. At least with the driver my converter uses (and I think with all drivers), the COM port number increments up by one every time a COM port is assigned to a USB device. So, plug the adapter in the first time and it is COM1. Eject it, plug it back in, and it is assigned to COM2, etc up through a very high number (65536?). The PLC software would only deal with COM ports 1-4, so I had to fiddle around in the system tools in Windows to delete the used COM ports and get it to start over at 1. T
  1. Newbie- Connecting a Bridgeport 800/22 DX-32 to a computer
    By ITGuy in forum Bridgeport and Hardinge Mills
    Last Post: 09-25-2011, 10:21 AM
  2. Need Help!- Need help connecting a Hurco VMX 50 to computer using WS_FTP pro
    By Ephraim in forum Computers and Networking
    Last Post: 03-14-2011, 03:29 PM
  3. Connecting BL30 to computer
    By Meduza in forum Servo Motors and Drives
    Last Post: 09-29-2010, 02:44 AM
  4. Haas dprint to external computer???
    By mt92 in forum Haas Mills
    Last Post: 09-01-2009, 01:23 AM
  5. Need Help!- Do you have a diagram for connecting GPD503 to 1994 Haas VF-1?
    By hamble in forum Haas Mills
    Last Post: 07-29-2009, 10:05 AM
