Results 1 to 4 of 4
Thread: Alarm 157 Mocon Watchdog Fault on VF-0E
    Jul 2008
    VIETNAM
    Anybody got alarm 157 Mocon Watchdog Fault before?
    I can't Reset that alarm when turn on the machine.
    I try replace a new mocon board from Haas by myself. But it still got alarm 157.
    I see on manual,
    Alarm 157: The self-test of the MOCON has failed. Test +12, -12, and +5 volt power at MOCON PCB. Unreliable power from LVPS can cause this alarm. Check alarmhistory for Axis Drive Faults. Afaulty axis driver can cause fluctuated or imbalanced low volt power to logic stack. Problem may be caused by a shorted coolant level sensor, voltage sensor from vector drive, or thermocouple sensor from X-axis ballscrew (lathe). Disconnecting cables, one at a time, on P34, P26, , P27, P28, P17, P21, and P22, may isolate the problem.
    I checked power from LVPS is ok.
    Pls help if you have any ideas about this alarm.
    Thanks & Regards,
    Jul 2008
    VIETNAM
    Anybody help!!!
    Registered KenFoulks's Avatar
    Aug 2010
    You said the LVPS was ok, what was the value? You can adjust the potentiometer on the LVPS PCB to tune in the correct voltage or have the LVPS replaced.
    Thanks,
    Ken Foulks
    Jul 2008
    VIETNAM
    Quote Originally Posted by KenFoulks View Post
    Den KenFoulks,
    Thank you, very good advice!!! I need adjust the potentiometer of LVPS.
    Thanks,
  1. Problem- VF-1 Alarm 142 A motor Z fault
    By schepw in forum Haas Mills
    Last Post: 05-20-2012, 02:50 PM
  2. Alarm 142 A Motor Fault
    By ToyMaker94566 in forum Haas Mills
    Last Post: 11-29-2011, 01:10 PM
  3. Need Help!- Alarm 126 - Gear Fault
    By JoBwan in forum Haas Mills
    Last Post: 03-07-2011, 08:10 AM
  4. Need Help!- 94 VF-0 17 Ground fault alarm
    By engine tech art in forum Haas Mills
    Last Post: 12-02-2010, 11:01 PM
  5. Problem- watchdog timer alarm on kryle vmc.
    By arpit in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 09-12-2010, 10:50 AM
