Results 1 to 7 of 7
Thread: parameter setting
    Jul 2009
    parameter setting
    I have a Haas VF-6 WITH A HR450 Indexer. A very heavy chuck has been
    installed onto the indexer.
    I would like to limit the indexer rapid feed rate. Is there a parameter
    that can be set to limit the feed rate for the indexer rapids? A(AXIS)
    thanks
    caddisfly
    Jul 2005
    Parameter 49 is A Acceleration, Parameter 50 is A maximum Speed.
    It may be a good idea to lower the acceleration as well as the speed. I had a tool turret with some long heavy tools and found just lowering the speed was not enough, I had to lower the acceleration to avoid getting tool change alarms.
    Jul 2009
    Quote Originally Posted by Geof View Post
    Thanks!
    I will give that a try.
    caddisfly
    Jul 2009
    Geof,
    What unit value do those to parameter settings represent?
    And are there any other A axis parameter settings that could be adjusted ?
    caddisfly
    Jul 2009
    I also would like to do the same with the x and y axis.
    What parmeters would control them?
    caddisfly
    Registered Seaside_Digital's Avatar
    Apr 2011
    Setting 34 in the Haas control will slow the fourth axis down depending on the part diameter. You have a range of 0 – 29.9”.
    If you tried setting 34 and it still feeds too fast for your application then you can lower the acceleration.
    Only adjust parameter 49 - Acceleration to a lower number. These are steps per second of the motor.
    Please keep in mind that if you are contouring a part on the A-axis. The finish may be affected because by lowering the A-Axis acceleration you are now disturbing the synchronization of the axis.
    If it’s just to position the 4th axis at a slower rate then it will be okay to lower the acceleration without a problem.
    Jul 2005
    Parameter 7 is X acceleration, 8 X max speed, 21 Y accel., 22 Y max speed, 35 Z accel., 36 Z max speed.
    1. Parameter setting of Fanuc 18i
      By alexium2007 in forum Fanuc
      Last Post: 04-08-2010, 01:37 PM
    2. Need Help!- Help with setting a parameter.
      By matt_773 in forum Milltronics
      Last Post: 10-05-2009, 11:17 PM
    3. CAPPS Parameter Setting?
      By xenginebuilder in forum Mori lathes
      Last Post: 04-25-2009, 10:37 AM
    4. parameter setting help
      By luis cuellar in forum Haas Mills
      Last Post: 07-18-2008, 12:39 AM
    5. G76 Parameter setting
      By Gorrell in forum Fanuc
      Last Post: 01-29-2007, 03:21 PM
