Results 1 to 2 of 2
Thread: Haas TR160Y Air Brake Problem
    Feb 2011
    New problem with the TR160y. When you turn the brake on (M10) all the air seems to be coming out of a release valve underneath. (see attached videos).
    I'm assuming a solenoid valve is stuck or something. Anyone have any ideas?
    Attached Files Attached Files
    Jan 2007
    Ca
    sounds like your break o-ring is leaking. If you send it back into Haas with an RA we can take care of that for you
  1. Z Axis Brake Problem
    By Brass Monk in forum Haas Mills
    Last Post: 07-08-2011, 10:00 AM
  2. New Machine Build- 600mm Box bend brake (Finger Brake, pan Brake)
    By RotarySMP in forum Bending, Forging,Extrusion...
    Last Post: 09-06-2010, 11:56 AM
  3. Need Help!- MIB press brake with Cybelec DNC 70 problem
    By Anoopka in forum General Metal Working Machines
    Last Post: 01-11-2010, 02:43 PM
  4. Barnes Press brake problem
    By Normsthename in forum Bending, Forging,Extrusion...
    Last Post: 07-11-2009, 01:26 PM
  5. Need Help!- HAAS TL 1 Brake
    By rtuls35 in forum Haas Lathes
    Last Post: 03-07-2008, 10:38 AM
