Page 1 of 3 123 LastLast
Results 1 to 12 of 28
Thread: Shop disagreement on rigid tapping, your thoughts?
    Aug 2011
    I was curious to get peoples thought on this, We have a disagreement in the shop.
    Should these be peck tapped, or finished in one shot? About 250 holes for each.
    Machine is a TM1-P with rigid tapping
    1st:
    Vanadium Steel Spiral Point Tap for Aluminum 1/4"-20, H3 Pitch Dia, 3-Flute, 3.150" L O'all,
    hole is 0.201" thru, 3/8" 6061.
    2nd:
    Vanadium Steel Spiral Point Tap for Aluminum 10-32, H3 Pitch Dia, 3-Flute, 2.76" L O'all
    hole 0.159" thru 1/4" 6061
    Registered Machineit's Avatar
    Mar 2010
    I'd shoot them straight through!
    Mike
    Haas VF-2, HA5C, Hardinge CHNC 1, BobCAD V23
    Jan 2007
    roll tap them straight through especially on the 10-32
    Apr 2005
    Paradise, Ca, USA
    One shot. If you peck tap things like that, I'd like to bid against you!
    Aug 2011
    A bit more info
    Just a bit more info, the tooling is what I have. And the whole peck tap thing is coming from the kid that designed the parts. He is telling me that the holes are deeper than the Dia. of the tap, so they have to be peck tapped.... ? this is what they taught him in school?
    Feb 2009
    I agree. Straight through, especially if its not a blind hole. Peck tapping is usually for hard materials.
    Mar 2010
    Quote Originally Posted by Chriseg1 View Post
    Ah yes, our great school system!
    Registered KenFoulks's Avatar
    Aug 2010
    Straight Through.
    Make sure you have:
    Good coolant concentration
    Good coolant flow
    Good drilled hole size
    Thanks,
    Ken Foulks
    Mar 2010
    Please remember the following too:
    My version of Machinery's Handbook is #23. Starting on page #1654 there is a chart of "Recommended Hole Size Limits Before Tapping Unified Threads"
    It has them listed by Classes, 1B-2B and class 3B. 1B and 2B are in one column and 3B is under another column. The hole sizes are listed in four depths each, To and including 1/3 D, above 1/3 D to 2/3 D, 2/3 to 1 1/2D, and 1 1/2 to 3D. D=the tap size, such as 1/4 inch.
    I'll list an example below of class 3B thread holes:
    -----------To 1/3 D,--------above 1/3 to 2/3 D-------2/3 to 1 1/2D,-----1 1/2 to 3D
    -------------Min Max-------------Min Max--------------Mini Max---------Min Max
    1/4-20-----.1960 .2013---------.1986 .2040 --------.2013 .2067-------.2040 .2094
    As you can see a 1/4-20 tap run in only .400 deep can use a .2094 hole and still be a legal class 3B. It is much easier to tap too.
    Using the largest hole possible and also within class limits will make the job a lot easier. This is especially important in tough to tap materials and small taps. We did a lot of 4-40's in excess of .450 deep in stainless and going to the larger hole size saved a bunch of broke taps. Just 1 or 2 thousands makes a tremendous difference in ease of tapping since the root of the tap on a 1/4-20 is larger than .201 inch.
    Most of the machinists I have worked with didn't know this, they only used the standard chart for tapping. So every hole for a 1/4-20 was the #7 drill, no matter how deep it was. On your holes just going to .203 for the 1/4 inch tap really relieves the pressure on the tap and has no effect on the strength of the thread.
    Mike
    Aug 2010
    U.S.A.
    Just give away some what of a trade secret, that's cool (sarcasm)...
    May 2009
    I have trained at many community colleges and must say that few of them actually understand CNC. They mostly teach manual machining with a term or two of CNC. My 17 yo son is wanting to get into the industry. He brought me a community college class schedule and I read through it and was not impressed. I got him a job at a very nice shop that will teach him more in 1 month than 2 years at a community college.
    Feb 2010
    Time to school him some more!
  • Page 1 of 3 123 LastLast
    1. Replies: 13
      Last Post: 07-03-2009, 07:43 PM
    2. What exactly is Rigid tapping? Why people always ask does it do rigid tapping?
      By cjchands in forum General Metalwork Discussion
      Last Post: 12-19-2008, 09:19 AM
    3. Tapping head or rigid tapping
      By Gregory_C in forum Syil Products
      Last Post: 10-18-2008, 01:49 AM
    4. Newbie- Initial thoughts on tapping
      By LuckyStrike in forum General Metalwork Discussion
      Last Post: 07-17-2008, 11:39 AM
    5. Rigid tapping or tapping head
      By wildcat in forum Industrial Hobbies (Support forum)
      Last Post: 09-24-2006, 01:08 PM
