Results 1 to 5 of 5
Thread: leaking air regulator bowl
    Mar 2009
    I've got a leaking air regulator bowl on the back of my 1990 Haas vf1. and need to know where or if i can get a replacement bowl
    The brand name is Wilkenson Part Number CB6-02 F00A D91
    it is a combination filter / oil mist.
    the bowl is a polycarbonate bowl and appears to have a crack just underneath the top rib next to the o-ring.
    I've done a super glue repair on it in the past but these repairs don't last very long.
    Attached Thumbnails Attached Thumbnails leaking air regulator bowl-p1010434.jpg   leaking air regulator bowl-p1010435.jpg
    Feb 2009
    Mar 2009
    Thanks underthetire.. it is wilkerson... my fat finger typing strikes again.
    Found the part.. Thanks to txcncman, anyone interested, the part no for the plastic bowl one of the following:
    Transparent Plastic Bowl Assemblies:
    with Flex-Drain™.............................................................. FRP-95-017
    with bowl guard, Auto Drain.............................................. FRP-95-015
    with bowl guard, Flex-Drain™.......................................... FRP-95-014
    http://www.wilkersoncorp.com/install...00_R2_0206.pdf
    Dec 2010
    What did the replacement bowl cost you if you don't mind my asking? I had a similar problem and found to my surprise that Haas sold the whole valve assembly for the same cost as just the bowl from an outside supplier; so I went thru Haas. In my case the machine was a model year 2000 and used a different valve though....... So I was just curious if you had Haas quote you too?
    Mar 2009
    I sent the same pic and comments in the op to my machine repair company i use.. on the 2n'd day of no reply's. Thanks to txcncman info, i did a google search and found a few on e-bay for $25.00 and free shipping.. expect it in the mail in the next the couple of day's. still no reply from the machine repair company.
    1. Bowl
      By dlenardu in forum Milltronics
      Last Post: 01-14-2011, 09:58 PM
    2. Air pressure regulator leaking
      By Matt@RFR in forum Haas Mills
      Last Post: 10-22-2010, 04:11 PM
    3. Cheap DIY Bowl Tumbler
      By dang in forum Mass finishing equipment/media/stratigies
      Last Post: 04-28-2009, 05:19 PM
    4. how do i cut a bowl with bob-cad
      By jrslick22 in forum BobCad-Cam
      Last Post: 12-12-2007, 02:17 PM
    5. CNC a dome/bowl without CAM software?
      By NotDylan in forum General Metal Working Machines
      Last Post: 04-03-2007, 10:29 PM
    Visitors found this page by searching for:
    Nobody landed on this page from a search engine, yet!
    SEO Blog
