Results 1 to 3 of 3
Thread: BPS (Blocks Per Sec.)
    Mar 2011
    us
    I have a Haas gr 712 gantry and am trying to run high speed machining on it. I have the 200 hours free trial on and loaded a g187 to the program and i get an error 178 divide by zero alarm. I also run vf 2 and vf 4 with hsm. but those i never put g187 in the program so am I really activating it? I talked to Haas tech and they asked if my program was over 1000 bps. That I don't know and not sure how to calculate it out either. I do run my programs from machine memory though, so I don't understand what that has to do with the program length. I have tried to change setting 191 to Finnish or, the g187 p3 e.015 and still, the same alarm. I posted this first in mastercam forum but they said maybe try here. thanks for the help.
    Registered KenFoulks's Avatar
    Aug 2010
    A 178 alarm is most likely a parameter issue. Have you restarted the machine? Call your local HFO and have them do a parameter check if you cannot get the issued resolved.
    A G187 is not necessary to activate HSM. HSM is active whenever the parameter for it is set to on.
    You can calculate BPS by using the formula found here:
    CNC - Haas Automation, Inc. - Solutions-Applications 3D
    Thanks,
    Ken Foulks
    Apr 2005
    Paradise, Ca, USA
    Quote Originally Posted by steve cline View Post
    g187 p3 e.015
    You need a leading zero after the E:
    G187 P3 E0.015
  1. Problem- BPS (Blocks Per Sec.)
    By steve cline in forum Mastercam
    Last Post: 10-24-2011, 12:06 PM
  2. 100 mm set up blocks
    By LEARN in forum CNC Tooling
    Last Post: 08-09-2011, 12:53 PM
  3. 1-2-3 blocks!?
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 05-07-2009, 02:25 PM
  4. end blocks
    By john86126 in forum Linear and Rotary Motion
    Last Post: 04-28-2008, 09:57 PM
  5. MDI ONLY 10 BLOCKS HELP!!!!!!
    By john-shipman@ho in forum 5T/5M
    Last Post: 12-25-2007, 12:34 PM
