Results 1 to 4 of 4
Thread: RO DI Water with Coolant
    Apr 2011
    Hi All,
    Does or has anyone used RODI water with their coolant?
    I have a small unit which I use for a fish aquarium and thought that it may be worth using it due to the lack of salts and solid impurities in the water it produces ... or is this just a waste of time ??
    Thanks ... Paul
    Feb 2010
    Using either will definitely increase coolant life.
    I have a 120 gal/day unit installed and it is used exclusively for coolant. You may be able to get by with a small RO system if the demand is not high. Just get a decent holding tank, atmospheric works better, to store enough to be useable when you need it.
    Apr 2011
    Mines a 100 gallon/400 litres per day @50 psi combined RODI unit, so I will put it to good use.
    Thanks.
    Jan 2011
    Interesting... I have a large RO/DI for an aquarium as well and I was wondering the same thing.
    I ended up going with tap water for the first fill.
    Does anyone know of a good discussion or article about coolant maintenance?
  1. Hard water and coolant question
    By l u k e in forum Haas Mills
    Last Post: 02-27-2011, 01:52 PM
  2. How to control the water coolant by mach3?
    By Mongkol in forum General Metal Working Machines
    Last Post: 11-17-2010, 04:06 PM
  3. Water based coolant - suppliers in Australia?
    By LeonM in forum Australia, New Zealand Club house
    Last Post: 11-13-2008, 04:51 PM
  4. Water Based Coolant
    By classictom in forum General Metalwork Discussion
    Last Post: 08-26-2008, 07:04 PM
  5. Coolant, mixing in more water
    By smellyfeet in forum General Metal Working Machines
    Last Post: 06-30-2008, 07:39 AM
