Results 1 to 2 of 2
Thread: 233 Jog Handle Cable Fault
    Registered Machineit's Avatar
    Mar 2010
    I have a 1996 VF-2. Yesterday it threw a fault, 233 Jog Handle Cable Fault, and it crashed a center drill into a piece of aluminum. No big deal, cleared it and it worked fine.
    Today it threw the fault again, but no crash just shut off the servos. This time just after I was jogging the table. Cleared it again and found no problem. Then a few minutes later it threw the fault while running a program.
    The cable has not been harmed of moved, so could this be the jog handle encoder going bad?
    Thanks in advance for the help.
    Haas VF-2, HA5C, Hardinge CHNC 1, BobCAD V23
    Registered KenFoulks's Avatar
    Aug 2010
    Yes, the jog encoder could be going bad. The encoder cable from the SKBIF to the Mocon may also be failing.
    Thanks,
    Ken Foulks
  1. Need Help!- VF2SS Error 234 Spindle Cable Fault
    By FP Racing in forum Haas Mills
    Last Post: 04-11-2011, 09:30 PM
  2. '08 vf3 spindle cable fault
    By ndrew2505 in forum Haas Mills
    Last Post: 01-04-2011, 08:43 AM
  3. Need Help!- '98 VF3 Brushless - error 182 x cable fault, or is it?
    By WillRitter in forum Haas Mills
    Last Post: 10-11-2010, 07:35 PM
  4. Spindle cable fault - TM1
    By f1jdm in forum Haas Mills
    Last Post: 01-09-2008, 03:51 PM
  5. spindle cable fault on VF-3
    By stefan2108 in forum Haas Mills
    Last Post: 07-18-2007, 02:26 PM
