Old 06-27-2011, 12:34 PM
umc1 is on a distinguished road
Haas X axis
Hello CNC Zone. I have a 97 Haas V2 mill. The x axis is starting to make a lot of noise and runs rough with the hand handle. The motor seems to fell hot to the touch. I checked for chips on the wire cables and all seems to be ok. Could it be the motor of amp on the axis drive?
Old 06-27-2011, 04:27 PM
djr76's Avatar
djr76 is on a distinguished road
Feel the ballscrew for excessive heat and to see if you can feel way oil on it, it be a thin film, not dripping. If its hot and dry, Id check the metering valves to see if they are clogged and not getting way lube to the ball screw. Happened to a 98' vf2 of mine on the X axis screw.
Old 06-30-2011, 12:56 PM
KenFoulks's Avatar
KenFoulks is on a distinguished road
I would recommend that you contact your local HFO.
There are two likely causes:
1. Mechanical bind due to dry ballscrew or linear guide trucks possibly due to lack of oil such as oil leaks, restricted orifices, etc. A high load for the axis would be a sign of a bind.
2. Electrical issue due to bad motor or amp.
Things you can try:
1. Check guide truck visually to see if dry.
2. Physically check the screw by disconnecting it from the nut housing to see if it feels rough to turn by hand.
Thanks,
Ken Foulks
Old 06-30-2011, 01:20 PM
ToyMaker94566 is on a distinguished road
My VF3 -Y- axis started making a different kinda sound like something was going bad, also sounded “growny” with the handle. My HAAS tech listened to it and said without hesitation said my -Y- axis "thrust bearing" was shot. I guess that's my next big fix.
Can't complain, 11 years and still going strong.
Old 07-06-2011, 05:14 PM
haas x axis fix
Thank you for your reply. After checking all the cables under the way covers. Checking the ball screw for play. I switched the axis amp in the back cabinet. I am not using my A axis amp so in this case it worked out. The axis runs good and no more heat or noise. Now I can send out the damaged amp fro repair. i'm told it's half the price of a new one. Thank again for your help. I hope this helps others in with the same problem.
Need Help!- Haas 4th Axis tranbell Haas Mills 4 07-31-2010 10:38 AM
Haas Aux. Axis ou812 Haas Mills 1 09-16-2009 07:32 AM
Haas 4th Axis TheGreenMachine General CNC (Mill and Lathe) Control Software (NC) 3 04-09-2008 04:32 PM
Haas 5 axis Kool Parts Haas Mills 6 01-05-2006 04:32 AM
