Old 06-18-2011, 03:16 AM
DaOne is on a distinguished road
Macros #6000 range?
I am editing some of the Renishaw probe macros. There are quite a few calls to the #6000 range. Is there a document that maps these out? The manual isn't much help...
#6001-#6277 Settings (read only)
#6501-#6999 Parameters (read only)
Anything that explains any of the Haas system variables (not just a range) would be a big help.
Old 06-20-2011, 12:45 PM
DruMor is on a distinguished road
I have never messed with macros and parameters, but I have done just a little bit with the settings. To find the variable number for a setting, add 6000 to the setting number. For example, setting 84 (Tool overload action) is variable #6084. To figure out how changing a setting changed the variable value, I would change the setting, go to MDI and set var #100 equal to what #6xxx I was working on, then went to the variable table to see what the value was. On on/off settings, off=0 and 1=on.
Need Help!- Morbidelli 502 Tria 6000 PLC matt_sheehy General CNC (Mill and Lathe) Control Software (NC) 1 06-15-2011 12:19 AM
TM-1 at 6000 RPM? DDLES Haas Mills 20 08-12-2010 03:26 PM
X3 6000 rpm for about 1 Dollar pzzamakr1980 Benchtop Machines 8 05-07-2008 11:19 PM
How does this BP Series 1 look for $6000?? NOCARRIER Bridgeport and Hardinge Mills 40 04-19-2006 11:13 AM
