im working on a haas tm 3 and am drilling through aluminum that is 6 1/4" thick. i was drilling through 4 1/5 " aluminum and the program worked great, but a quarter of the way through the machine stopped because the drill bound up in the hole. probably because of improper chip clearance. then i edited the program and slowed the feed rate down and set the retract height to .2 inch above part. then drilled the same hole and the drill shattered. im using deep hole peck drill taking .075 each peck feed rate was 3.25 then slowed down to 2 after the slip, then the drill broke. is there a better way to clear the chips out of the hole or what am i doing wrong? any suggestions are helpful thanks, matt |
| You did not mention the size of the drill nor the rpm of the drill and that we will pretty much need. Slowing your feed is probably what hurt you. Too much time in the hole without coolant and it will bind up. Make sure that you use full rapid speed and use shorter peck strokes. Short pecks at slow feed make long stringy chips that will clog. A good solid chip will travel up the drill and get thrown off of the drill during the retraction. The longer that the drill is engaged the greater the chance it will max out the power of the machine too. Give us more details. Mike
__________________ Haas VF-2, HA5C, BobCAD V23 Last edited by Machineit; 06-10-2011 at 05:39 PM. |
| and flutes are 6 1/5. |
| I don't know if you are doing production or just drilling a few holes. Do you have coolant on it. Sorry, I'm not used to TM mills, always had VF's. But, if you are just drilling a few holes, program it with a G83 with shorter pecks and higher feeds to help clear chips. Your drill should not slip. Was that in the holder? Say, G83 Z-????? R.1 Q.03 F10. Up your RPM a little if you can. Don't know your machine. You might consider drilling a pilot hole of about 3/8" to save power on the 17/32nds drill. Again, don't go slow or you will seize up the drill or load it up with chips. Good luck learning. Mike
__________________ Haas VF-2, HA5C, BobCAD V23 |
not really production just running 4 parts with 4 holes each in them along with other things to it. but ill try using small pecks with higher feeds. going to be a little slower but as long as it gets done then ill be happy |
| If I were you, I would have the drill bit in a collet tool holder. I try to avoid using drill chucks for anything larger than 1/2". I'm skeptical about turning a drill bit down to fit properly in a tool holder... Make sure your drill bit is sharp. To answer your question, I don't think chips will fall through the bottom as well after a .25 step drill. |
#10
but i do appreciate your help. maybe step drilling wont work that gread with the chips |
#11
| I think most of it is due to the slow feed. If it was me I would give 1060 RPM with a 9.41 feed a try. If time isnt a factor make your peck depth .05. Make sure your hitting the center of the flutes at a downward angle with coolant to flush off the chips and do a full retract on every peck. Make sure you using a good quality sharp bit. I would really recommend getting a collet holder. Without that bit running true you have no chance at drilling accurate deep holes. Also you should be using a spot drill to start the hole. Without doing that the drill can walk on start. Your drill is held rigid at an offset to the hole and the deeper you get the more side load you get until it finally fails. |
#12
| If I understand all your parameters correctly: 17/32 drill (.5313); 6061 Alum; hole depth 4 1/5? or 4.200(strange to see a 1/5 call-out, it's like saying a 3/16-32 tap instead of a 10-32, it's just not done. ;-). Make sure your coolant is properly mixed, to watery and you'll seize for sure. Running in a drill chuck, (Not impossible nor recommended), here is what I would be starting with: First, with a hole that deep, definitely spot drill your hole. Then I would drill in about 1/2 to an 1" in with a stub length drill then the rest with your tapper length drill. My feeds and speeds for the the tapper length drill would be Speed: 2500 rpm G83 Z-4.2 Q.1 R0 F25. By keeping your "R" plane low, no chips can fall back in. Full rapid, don't dittle around in the hole, get in - get out! The drill chuck is going to chatter with a long drill, a collet is recommended but turning the shank will work fine if you trust spinning it down true. I don't know much about the TM machines in terms of power but the less you have, the more you'll need to stay up in the RPMs. Takes more torque to spin it slow and a lighter machine will stall under a load. As mentioned above, short quick pecks will get you thru it. |
| Just IN- G83 deep hole drilling | mike852 | CNCzone Club House | 2 | 02-08-2010 12:34 PM |
| Need Help!- Hole Drilling | jsanchez177 | DIY-CNC Router Table Machines | 3 | 02-02-2010 12:38 PM |
| Hole drilling help | stevehuckss396 | General Metalwork Discussion | 23 | 01-27-2008 01:15 AM |
| Drilling a .010 hole | CoolhandLuke | General Metal Working Machines | 7 | 03-25-2007 10:44 PM |
