Old 05-30-2011, 07:43 PM
WATERJET71's Avatar
WATERJET71 is on a distinguished road
compressor
Ok I have a question for those that have a minimill.if I install a 60 galon compressor to run with my minimill. and if I dont use anything else that use air. how manytimes or how often do I expect the compressor will turn ON?? the reaon is I will have it in my garage and dont want to make toomuch noise.
thank you for your help.
Old 05-31-2011, 01:15 AM
Delw is on a distinguished road
Baring any air leaks, not often. unless you have a ton of tool changes and blow the airhose alot or use a 4th axis.
There is no law about having a compressor in your garage that I know of, hell most people too anymore.
Old 05-31-2011, 08:19 AM
Kool Parts's Avatar
Kool Parts is on a distinguished road
Couple of tips for the compressor, rubber mounts. The compressor will beat on the floor and reverberate throughout the shop. Also build a insulated enclosure around it. Or they make sound blankets that you can hang like curtains around it.
Nothing worse that hearing one of them beating its guts out all day.
Gary
Old 05-31-2011, 05:17 PM
Pondo's Avatar
Pondo is on a distinguished road
If you build an enclosure around it, make sure there is a forced ventilation of some sort in it to avoid overheating the compressor.
I boxed mine in and had the compressor overheat and destroy itself in about 2 months. $500 in repairs and a 6" fanned duct later and it's been running fine for 4 years.
Apparently I don't know anything, so please verify my suggestions with my wife.
DIY air compressor joecnc2006 Hobby Discussion 17 01-29-2011 03:09 PM
Problem- compressor help advt001 General Metalwork Discussion 1 04-07-2010 10:04 AM
New Compressor Help 1ctoolfool Haas Mills 1 01-31-2007 05:52 PM
Compressor Crazycorkey Jet Engines and Ram Jets 8 01-30-2007 03:02 AM
rotary air compressor omegaghost I.C. Engines 5 01-14-2007 06:19 PM
