Old 05-20-2011, 08:22 AM
don42970 is on a distinguished road
VF2 Run program with door open !!
How can I run a program with the door open, the setting 51 doesn't override the door open alarm on my machine (it's a 2010 model). I need help....Thanks,Don
Old 05-20-2011, 08:38 AM
You don't, unless you fudge the lock mechanism or trace wiring and bypass sensors. Which is not a wise thing to do during the warranty period.
http://www.cnczone.com/forums/haas_m...oor_locks.html
http://www.cnczone.com/forums/haas_l...cks_crazy.html
Old 05-20-2011, 12:50 PM
mfgbydesign is on a distinguished road
I had the same problem setting #51. Changed it to "Y" & nothing changed. Hit "write" and respond to warning "are you sure" sort of thing, hit Y.
You have to do this every time you power up.
Old 05-24-2011, 12:16 PM
djramm is on a distinguished road
Newer Haas mills need parameter 57 door stop spindle changed from 1 to 0 as well as changing setting #51.
DJ@S&W
Open tool changer door Jedi Haas Mills 19 04-19-2011 05:14 PM
Newbie- Door Open North Forty Haas Lathes 2 09-02-2010 10:46 AM
Door open request zippyd Daewoo/Doosan 11 06-07-2010 10:23 PM
TL-1 door open alarm won't go off! donsbad89 Haas Mills 5 09-24-2009 10:01 PM
kira vtc30a door won't open nevron General Metal Working Machines 0 11-28-2008 08:30 AM
