Old 05-11-2011, 03:29 AM
DaOne is on a distinguished road
How to correct reversal spikes on haas?
Long story short my CPU board required replacement. The software that was on the new board was the higher than what was on the original. All settings, parameters and serial number were put back into the machine. Everything works however I am seeing reversal spikes in testing that were not there before. Its not a backlash issue as it was tested and spot on. This is a 1995 VF-2 (brushed) with version 8.32n (old version was 8.24n). I need to know what parameters adjust this on a haas.
Old 05-12-2011, 01:33 AM
Nobody?
Old 05-12-2011, 11:14 AM
Wizzard of H is on a distinguished road
reversal marks
What software version do you have now?
Parameters 138 and 139 are used to compensate for reversal.
Use of these parameters really requires a ball-bar setup to check the results.
Old 05-12-2011, 11:15 AM
Also might check old parameters from original board and use parameters 138 and 139 from there.
Old 05-12-2011, 03:58 PM
138 is -192
139 is 192
Does this sound correct?
Old 05-12-2011, 04:09 PM
Reversal spike
Those look like the right range of numbers BUT the sign is important. One is negative and the other is posiitive. It is still best to get the same numbers the machine had at shipment. The parameters would have been printed out. It also looks like parameter 138 shouild be PLUS and parameter 139 should be MINUS. You have the opposite. How old? What serial number?
Old 05-12-2011, 04:14 PM
I sent you a PM with the info. Maybe you are able to get me the original .par file?
Correct Post for HAAS mini mill? Mad Engineer SprutCAM 1 04-18-2011 08:27 PM
Correct SprutCam Haas Post for TM-1 mecheng10 SprutCAM 1 03-28-2011 01:50 PM
G02 G03 reversal dek Fagor Automation 4 07-24-2010 07:01 AM
Stepper motor reversal andrewbishop66 Bridgeport and Hardinge Mills 1 03-15-2007 03:01 PM
Protecting PC from voltage spikes? Splint Computers and Networking 9 05-11-2004 06:54 PM
