| Thank you for the help with 234 spindle cable fault. I cleaned the connector on the spindle encoder, and the wiring harness connector. Has stopped doing that for now. When I power up the machine (VF3), after power up, say 30 secs to 1 minute, get a motor overheat, or A motor overheat, for 1/2 second then changes to 112 no interupt. This locks up the display. The second power up might be for 2-5 minutes before this happens. Then it might do it 2-4 more times, or not. Then I have run machine for 1/2 hour, to finish what ever I was doing, with no problems. Any help would be appreciated. Stephen |
| I am a factory tech. These alarms point me to one of two things. You will need to first check the logic voltage to the mocon pcb. You will be looking for +12 -12 +5 volts. If your voltage is good at the pcb then you have a back mocon. If you need any more info please let me know |
| Did you try unplugging and plugging back in the plugs on the power PCB? http://www.cnczone.com/forums/haas_m...dle_cable.html |
| Newbie- Wiring Optical interupt switch to BOB | Simon C | General Electronics Discussion | 8 | 02-21-2011 10:47 AM |
| Optical interupt switch implementation. | owhite | General Electronics Discussion | 26 | 07-26-2009 04:27 PM |
| VF-2 1998 | wsbat | Haas Mills | 3 | 02-26-2009 08:31 AM |
| Newbie- Please help with an optic interupt switch | antichip | General Electronics Discussion | 7 | 09-02-2008 09:47 PM |
| Clock interupt or something? | thedoctor | Controller & Computer Solutions | 2 | 07-24-2008 05:41 PM |
