Old 05-04-2011, 03:49 PM
zonked is on a distinguished road
vf-0 alarm 149 spindle turning
I have a 1994 haas vf-0 that is showing alarm 149 spindle turning. The unit also has a magnetek gpd 503 drive that has no display at all or lights on. please help guide me to troubleshoot this !
thanks in advance
Old 05-04-2011, 05:55 PM
KenFoulks's Avatar
KenFoulks is on a distinguished road
If the drive's voltage is good going in, most likely it needs to be replaced.
Thanks,
Ken Foulks
Old 05-05-2011, 12:38 PM
haastec is on a distinguished road
+1
Your local HFO should be able to help you out but most likely they will upgrade the GPD503 as it is no longer supported.
Alternatively, you can do a search for companies that repair these drives. ( I have no personal experience with any to recommend)
If memory serves correctly and you are comfortable removing the cover of the drive, there should be some fuses that you can check to make sure they are good.
Regardless of who works on this machine, grab a chair and personally make detailed notes of which wires are connected where so you have a good reference of the original connections, trust me!
Good luck!
Old 05-06-2011, 12:57 PM
schlobby is on a distinguished road
If there is no display on you drive it will need replacing if you have 230 volts going into it. If your machine is a brush machine it will need a new drive, if it's brushless, it will need the vector drive upgrade.
1992 VF2 Alarm 123 spindle Spindle Drive Fault dafowfidy Haas Mills 15 05-14-2012 01:32 PM
Need Help!- 750 ALARM SPINDLE-1 ALARM DETECT (AL11) PICMAN Fanuc 9 03-27-2011 06:14 PM
Need Help!- ALARM 9034 in Fanuc oi mate-TB turning center shavad_ind Fanuc 5 02-03-2010 06:41 AM
HELP-Spindle not turning bherr Bridgeport and Hardinge Mills 4 04-20-2007 12:11 PM
Alarm 149 Spindle turning *HELP* ali203joe Haas Mills 3 02-21-2007 05:54 PM
