Looking at picking up a couple of these and sticking system 3r pallet changers in front of them. Just need the 5 axis for positional at this point but...well you know..if you have it you just have to program for it. ![]() Like to know what you have seen first hand with the trunnion system, backlash problems, 5 axis problems, whatever. Thanks, Gary |
| Whe you start stacking pallets then parts you run out of z really fast on the machines and x-y. I dont know how large your parts are or how tall the 3r pallets are, but I know that with the erowa pallets I use with the power chuck and pallet part height becomes a limitation depending on if you are end cutting or side cutting either way. You can download a dimensional drawing from haas and work it out by adding you pallet dimensions onto the table center height. If you really wanted to maximize, I thought about remaking the platter and integrating the chuck into it which would save about 2" but would be probably too much money. I think a vf3-YT withe a trunion is a better fit with the increased z axis height and larger Y would be a big improvement. Or get a vf-2 YT and add the trunion instead of the packaged 16" trunion machine. |
| MKproto, Thanks for the reply. The parts are small so room is no problem, but the 24 tool changer is all you can get on the VF2 platform. So I have considered going up in size to get the 40 tool changer anyway. Are you using the trunnion now, and if so what are your thoughts? Thanks, Gary |
| I am not usong it now but have used all the haas 5axis tables with the exception of the tr110. Accuracy with a proper setup you should be able to hold. 002 or better without any shifts face to face simultaneous depending on about the same but will depend on programming etc. I have held .002 true position on 12" square parts on an old hs1 horizontal with a 210 5th axis. Tooksome backlash moves but once set repeated no problem. I ran that machine hard put it away wet and it is still running today at another aerospace company. I run a 4th axis setup on my vm2 and hold less than a thousands with no issues. I even pull the erowa pallets off switch jobs pop it back on when done a start where I left off. Zero issues. Rotary speeds are not fast but it gets it done. |
| Need Help!- 3axis to 5axis | pinguS | SolidCam | 3 | 01-02-2011 10:02 AM |
| help me design 5axis cnc (please?) | Nick_Black | Open Source CNC Machine Designs | 5 | 07-08-2008 06:45 PM |
| Snk cnc 5axis index milling help? | Chris Rees | General CNC (Mill and Lathe) Control Software (NC) | 0 | 02-09-2008 08:55 AM |
| Need Help!- what is the best 5axis software | 5axisatm | General CAM Discussion | 5 | 02-08-2008 04:52 PM |
| 5axis Help | jybute | Haas Mills | 0 | 11-22-2006 08:10 AM |
