Old 04-25-2011, 12:55 PM
PEU's Avatar
PEU PEU is online now
PEU is on a distinguished road
Need wiring diagram of Haas HRT 160 4th axis
The cable that goes from the control to the 4th axis unit is giving a fault error, I want to test continuity but I don't have the wiring diagram, is not provided in the operator manual, this is the connector:
I would like to know what goes where from this connector to the square box on the top side of the 4th axis unit.
Any help will be really appreciated, you know what downtime cost these days...
Thanks!!
● Distribuidor Syil en Argentina ● "www.syil.com.ar" ●
Old 04-26-2011, 06:42 AM
PEU's Avatar
no one?
Old 04-26-2011, 12:11 PM
Wizzard of H is on a distinguished road
rotary connector
This is a brush rotary table.
Problems are not in the connector.
Most frequent failure is breaks in the cable.
Next most likely is coolant getting into enclosure with motor.
Knowing the alarm you get helps.
Pinout at 17 pin connector is:
L R +5 v
K R/wh logic gnd
A Br/wh A
B y/wh B
C or/wh Z
M br /A
N y /B
P Or /Z
T bl overheat sw ref logic gnd
D bl/wh home sw ref +5/logic gnd
E & F wh motor +
J & H bl motor –
G gr/y earth gnd
R 115 VAC air solenoid
S 115 VAC air solenoid
Old 04-26-2011, 08:00 PM
PEU's Avatar
Thanks a TON !!
will check the cables and write down the alarm codes.
Problem- HAAS HRT210 wiring diagram jcassidy Haas Visual Quick Code 1 03-11-2010 02:34 AM
Need Help!- wiring diagram prabhu58 General Metal Working Machines 0 11-10-2009 10:56 PM
320 ERR/RES wiring diagram schwinndk Gecko Drives 2 10-22-2009 05:33 AM
Need Help!- Wiring diagram jdmyers Bridgeport and Hardinge Mills 6 11-03-2008 04:25 AM
help with wiring diagram for C6 CNC JDsto Syil Products 6 01-09-2008 06:37 PM
