Old 04-19-2011, 11:11 PM
TheArmoury is on a distinguished road
Haas VF1 Alarm Code 110/105
I've got a '91 Haas VF1 that's been running just fine. Today I was using it manually to drill a hole through a new fixture plate to bolt it to the table. I've gotten a 105 and a 110 Alarm. 110- excessive load on z axis motor. 105- too much load or speed on z axis motor. The 110 is the most prevalent and comes back within five seconds of resetting the codes. As such, the z-axis won't move (drill bit was still in contact with the fixture plate but I pulled it out of the toolholder and was able to activate long enough to release the toolholder). I pretty sure this machine has no brake but rather uses the big counterweights. I've found a few hits on the web about possibly the brake not releasing the z axis servo motor but since I'm not sure it's even GOT a brake (but rather the counterweights) I'm at a loss.
Anyone deal with this? I can deal with my lathe being down but in addition to EVERYTHING else I do with the Haas, I also engrave my serial numbers on my products with it and have a bunch to do... And a certain governmental entity frowns heavily upon my products with no serial numbers... PLEASE HELP! Trying to avoid, hopefully, a Haas service call...
-J. Burnett, V.P.
Armoury Guns/ARMTAC Machine
Old 04-20-2011, 02:05 PM
Wizzard of H is on a distinguished road
Z servo errors on a VF-1
That machine definitely has no brake on the Z axis. It has a counterbalance weight and brush servo motors.
You can slide the Z axis way covers aside and see if the motor and screw can be turned at all. If they can, it is likely motor or drive card. If not, it is likely the screw.
(Also make sure the counterbalance is still there.)
On a 20 year old machine, this might be the motor brushes.
If drive card is suspected, you can swap Y and Z quickly to see where the problem goes.
Alarm 157 Haas VF3-SS rshields21 Haas Mills 7 12-09-2011 02:03 AM
fanuc program code vs. Haas code sixty8frbrd Fanuc 6 03-10-2011 09:05 PM
Alarm 233 on Haas VF-1 hoi.le Haas Mills 9 02-10-2011 08:30 PM
ALARM shuttle drawbar alarm haas timmydabull Haas Mills 27 10-30-2009 08:27 PM
alarm 408 servo alarm "serial not RDY", αP18 fanuc mtor code sting Fanuc 0 01-01-2008 09:03 AM
