Old 04-14-2011, 06:07 PM
2xEngineer is on a distinguished road
Software travel limits?
Here at work we have a rather large fixture setup on our Haas VF6, so large that if the machine is inadvertently sent home it will crash the fixture through the sheet metal and doors. We knew it was inevitable, and just today someone caught it before it did any severe damage, but there is a nice big bulge on the front of the sheet metal now.
Anyway, I was wondering if there is anyway to impose arbitrary limits on the travel that will prevent this from happening? Any help is appreciated.
Old 04-14-2011, 07:47 PM
Wizzard of H is on a distinguished road
need shorter travel limits
The only way to do this is by changing the travel limit parameter.
It can only be done on the negative side of travel.
The axis must still be able to get to the home switch.
Old 04-14-2011, 08:25 PM
Matt@RFR is on a distinguished road
How about mounting your own micro switches and wiring them in to the Estop circuit?
Old 04-15-2011, 10:04 AM
travel limits with E-stop?
That may sound like a simple solution but you have to deal with two problems.
1) the motion may not stop quickly with E-stop; the axis could coasst farther.
and
2) getting out of that situation is hard as E-stop is active.
That is a design like I first saw in a Fanuc control 26 years ago. I think they still haven't quite gotten away from that unfortunate approach to travel limits.
Old 04-15-2011, 10:26 AM
beege's Avatar
beege is on a distinguished road
Does the control advertise any "interference zones" as some fanucs did or still do?
Old 04-15-2011, 10:34 AM
Well, that is a shame. If we had a problem with it ramming the column that would help. Is there any non hardware wat to reassign home, or lock out the ability to home the machine?
Need Help!- Deckel DMC 60 T G7 Travel Limits mikefitz Deckel, Maho, Aciera, Abene Mills 1 05-25-2010 01:30 PM
Need Help!- Lazy Cam not posting Fast Travel as Fast Travel astainless LazyCam 0 02-24-2010 02:31 PM
software limits woodman08 Mach Mill 0 10-29-2009 07:51 AM
Need Help!- Setting Software limits bherr Bridgeport and Hardinge Mills 1 04-05-2009 11:31 PM
Problem- Kondia/Dynapath 10M Travel Limits Problem ballchain General CNC (Mill and Lathe) Control Software (NC) 11 05-07-2008 06:41 PM
