Old 04-11-2011, 10:31 AM
Jedi is on a distinguished road
Open tool changer door
Im am on a tm1p fully enclosed. I am trying to open the tool carousel door. On a fadal it is possible and makes tool loading easier. Is it possible on this haas?
Not saying a fadal is better!
Old 04-11-2011, 10:56 AM
Donkey Hotey's Avatar
Donkey Hotey is on a distinguished road
Good god, man, keep your hands away from that flippin' door! No, you can't open it without taking out screws. Don't try.
Why on earth would you want to load tools through the door? Put it in the spindle and turret-fwd like everybody else.
Greg
Old 04-13-2011, 11:31 PM
lkenney is on a distinguished road
because it is faster to load a bunch of tools directly into the tool changer. No waiting for the spindle to to go up and down and the TC to move back and forth. I was surprised on how well I liked doing it that way when I started using Fadals recently. There is no way to do the same thing with a Haas
Lowell
Old 04-14-2011, 01:44 PM
behindpropeller is on a distinguished road
Sounds like a good way to crash your machine into the toolchanger.
Old 04-14-2011, 02:21 PM
Excelmachine is on a distinguished road
Lowell
Having used a Fadal for many years, I too have found this to be a nice feature. But realistically, with the new interlocks and safety features, I can't see Haas ever implementing this. It was pretty safe to do this and allowed access to clean inside of there too. The Fadals didn't have the collapsing covers in the slots so chips got inside there at times and would need to be cleaned out.
Old 04-14-2011, 06:14 PM
Pondo's Avatar
Pondo is on a distinguished road
Most other machines allow this.
Personally, I would not ever use it on a double arm toolchanger, the pockets get all mixed up anyways. Plus I'd need to call them up into the spindle to touch them off anyways, even with an umbrella changer.
It would be nice to be able to get in the umbrella changer and clean it out though. The sensors get any coolant splashed on them and screw up easily.
Apparently I don't know anything, so please verify my suggestions with my wife.
Old 04-15-2011, 12:46 PM
Bryan33 is on a distinguished road
All yo uhave to do is push ATC FWD. When the head goes up hit Feed hold then Estop. The TC will be in and the door will be open. When your done simply hit Zero Return and then Single axis
Old 04-15-2011, 02:23 PM
This will open the door and it is useful for blowing junk out of the carousel housing.
But it is useless for trying to load tools into the chamber instead of into the spindle. If you do this procedure and slide a tool into the fingers on the carousel this tool will crash into the spindle nose when you do a toolchange.
Old 04-15-2011, 02:47 PM
You can use a m39 to move the carousel
Old 04-15-2011, 02:50 PM
This is a dumb thread.
By the time you press 20 buttons to open the door to the changer you can load each tool by advancing the toolchanger. Your not saving any time and increasing the possibility of crashing into the toolchanger.
Tim
  #11   Ban this user!
Old 04-15-2011, 04:16 PM
Not after you push Estop.
And if you release the Estop and press Reset you will gate a Shuttle In alarm.
  #12   Ban this user!
Old 04-18-2011, 04:02 PM
SBC Cycle is on a distinguished road
Tim
I was going to ask this question as well
Yes, the most useful purpose is to clean the carousel. The Fadal doesn't have the retractable clips like the Haas to keep shavings out of there. The clips don't help with plastic though, it will find it's way in there no matter what you do. I ran plastic all weekend long in the VF3 and it's everywhere.
And it IS a lot easier and faster to load tools with the carousel open. Just saying
Tags
carousel door, tm-1
Newbie- Door Open North Forty Haas Lathes 2 09-02-2010 10:46 AM
Door open request zippyd Daewoo/Doosan 11 06-07-2010 10:23 PM
Need Help!- 2216 FX Run spindle with door open??? Chuck Pressure Fadal 13 10-26-2009 09:26 AM
TL-1 door open alarm won't go off! donsbad89 Haas Mills 5 09-24-2009 10:01 PM
Need Help!- OKK G4 tool change door open dannystooblue OKK 2 09-18-2009 08:26 AM
