Results 1 to 5 of 5
Thread: HS-1 Dial Indicator Recommendations
    Nov 2010
    America
    Hi everyone,
    Second post here ~ absolutely new to CNCing but have some outside help coming in that we're trying to get all of the right tools ahead of time. We bought a used 1998 HS-1 and need a dial indicator... there seem to be hundreds of choices and we realize that they are not particular to any type of CNC machine.
    But I'm curious for recommendations from guys out there with this age machine and what you use to do the offsets and prep work. What would you recommend?
    We are going to use this machine to produce our own parts and won't be switching out programs very often at all. So to a large degree we hope to have a setup run for weeks if possible.
    Thanks!
    Registered KenFoulks's Avatar
    Aug 2010
    Almost any indicator will work. If your part has .005 tolerances, get a .001 indicator. There is a trade-off=
    Lower Increments (.0001) = more precise, expensive, harder to use.
    Higher increments (.001) = Cheap and easy to use, cannot be used for tighter tolerances.
    My preference = .001 Dial indicator and a .0001 dial test indicator
    Thanks,
    Ken Foulks
    Registered dougtyler's Avatar
    Jun 2007
    Working with a horizontal spindle is alot different than working with a Vertical spindle, as far as indicating is concerned. You want to make sure that whatever is holding the indicator is rigid enough, not to be affected by gravity.
    Aug 2010
    Quote Originally Posted by dougtyler View Post
    Absolutely agree
    Thanks,
    Ken Foulks
    Nov 2006
    A good quality magnetic base can make any dial indicator pretty versatile. Handy in the manual side of the shop too..
    1. I can use a drum dial as a dial indicator can't I?
      By slashmaster in forum Benchtop Machines
      Last Post: 11-03-2010, 01:10 AM
    2. Recommeded dial indicator.
      By Kalvin in forum Calibration and Measurement
      Last Post: 01-01-2009, 10:55 AM
    3. Dial indicator question
      By cwm9 in forum Metal Working Tooling
      Last Post: 12-17-2008, 03:15 PM
    4. Dial indicator
      By hkrok in forum Product and Manufacturer Announcements
      Last Post: 08-16-2007, 08:49 PM
    5. what does dial indicator use to measure?
      By cnc2k in forum General Metalwork Discussion
      Last Post: 07-16-2005, 08:20 AM
