Old 04-02-2011, 03:55 PM
CNCErnie is on a distinguished road
Smile Haas VF-1 Transmission Overflow Question
I purchased a used Haas VF-1 and just changed transmission fluid. I noticed that the overflow next to the drain plug does not have a plug in it. Should it have one, or not?
Old 04-03-2011, 06:42 AM
Machineit's Avatar
Machineit is on a distinguished road
You may have answered your own question if you read it again. It's an overflow, would you plug it?
You fill until it overflows and then stop filling if I remember correctly.
Mike
Haas VF-2, HA5C, BobCAD V23
Old 04-03-2011, 08:07 PM
Thanks Mike
Normally, I would not plug an overflow. But I was confused because it was threaded for a pipe plug. I didn't know what to think!!!
Old 04-04-2011, 01:02 AM
Matt@RFR is on a distinguished road
Could it be threaded for a breather of some sort? I don't have a transmission on mine so am no help beyond that.
Old 04-04-2011, 08:34 AM
Normally I would plug an overflow port, with a breather plug to keep dirt out.
Something like this:
Breather vents for gear cases, breather plugs and filters
Old 04-07-2011, 07:19 AM
haastec is on a distinguished road
The drain plug sits almost flush with the tank itself. The over flow tube sticks down a little and the tube is trimmed at an angle. To answer the original question; no, you do not plug the overflow tube. It is as Machineit said, fill until it comes out the overflow tube then stop. That simple.
Transmission question... l u k e Haas Mills 11 03-24-2011 05:41 AM
way oil overflow? Brendan Haas Mills 2 01-20-2011 10:11 PM
Need Help!- Buffer overflow OKUMAN Okuma 3 02-08-2010 02:53 AM
Problem- OVERFLOW HAAS VF3 daytona81 Haas Mills 4 05-04-2009 05:41 AM
Haas Transmission Wiring Rcky123 General Metal Working Machines 0 05-05-2007 10:36 PM
