Old 03-30-2011, 05:36 PM
riverracer is on a distinguished road
power outage restart
just had a power cut, program and machine stopped thru a cut...
how do i restart the machine to clear the job before power up restart ie: 'y' axis only
how do i do this if say i had a slitting saw and it was stuck in the job?
thanks
HAAS TM-2
Mastercam X4/X5 - Level 3 - Solids @ work / HLE @ home
Old 03-30-2011, 06:11 PM
ToyMaker94566 is on a distinguished road
Before you turn it back on, close the e-stop. Now power back up and clear all alarms. "Single axis return" "Y", if that gets you out of the work piece, then "X" then "Z""....
I had a power out once and it burned a fuse, might have to deal with that too.
Old 03-30-2011, 07:36 PM
thanks
Setting 53 JOG W/O ZERO RETURN is your friend in a case like this.
Power the machine up BUT DO NOT PUSH Power Up/Restart to home the axes.
Go to Settings, find 23 and turn it ON. Now you can jog any of the axes VERY CAREFULLY because you have no protection if you start jogging it into a hard stop.
Once your tool is clear and the Z axis can lift without damaging anything push Power Up/Restart.
Power Outage ? Phishaholic Tormach PCNC 17 06-29-2009 05:15 PM
Power up restart with large 5 axis parts Homing out A and B kojack Haas Mills 2 05-21-2009 04:16 PM
Restart from power failure. Farproducts Excitech routers 2 04-01-2009 06:37 AM
Need Help!- Restart jhersh Mazak, Mitsubishi, Mazatrol 1 12-05-2008 07:20 PM
Power outage during machining walter DIY-CNC Router Table Machines 7 08-02-2005 09:13 AM
