| Turn on Single Block (if you haven't already done that) and step through the program until it stops and see what is on the line it stops at. My manual says invalid address format is: "An address A....Z was used improperly". Which is not very helpful. ![]() You might have a decimal on a number that should be an integer, such as L2. or something similar.
You have a decimal on the speed command, should be an integer.
![]() If you are calling for a G41 or G42 in your in your program, the tool offset goes in the program body during a straight line move. Where you put you D07 is where I put my M08. Mike
__________________ Haas VF-2, HA5C, BobCAD V23 |
#10
| Luke No offence but after reading all your posts and questions and some answers, My Suggestion is you buy a book on gcode better yet just goto haas and down load there training manual, then read it 2-3 times., if you dont understand it pull the power from your machine until you do. Your going to cause yourself alot of grief and cost with screwing up. ALSO DUMP YOUR CAD CAM PROGRAM Untill you learn what g codes it. your cadcam program aint going to help you a bit if you dont have a clue what the feeds and speeds are or what g code is. WRITE programs by hand UNTIL you are comfortable, then play with the cadcam stuff, your going way to fast and not grasping the concept. BTW if you had a minus 300 in your program you could have destroyed your machine. Luckly the machine saw the number ( another reason NOT to screw with parameters unless you know what your doing). what I am getting at is you didnt know enough to see that, that 300 number was wrong. what if the program had -4 or -5 inchs how would you know if it was good, you wouldnt have gotten an alarm and posibly destroyed your machine. TURN THE POWER OFF READ ON PROGRAMMING and G CODE. and pull the plug from your CADCAM PC. Again not trying to be nasty just stating facts and trying to save you a ton of money caused by your screwups. Delw |
#12
| The benefit to learning the write by hand is that you are able to monitor the program as it runs. I have run programs written by others and have hit the panic button often just before the crash came. Mike
| Need Help!- Green "Tool Reset" prompt, but we have no button to push for that, or a tool changer. | tomdbiggs | Milltronics | 8 | 02-01-2010 09:45 AM |
| Need Help!- The Green button won't go :-\ | Shanghyd | Bridgeport and Hardinge Mills | 3 | 11-19-2009 04:29 PM |
| the green button | msn_jrd | Tormach PCNC | 1 | 07-20-2008 10:02 AM |
| "INPUT BUTTON NOT FUNCTIONAL IN PROGRAM MODE" | offroadxx | Fanuc | 0 | 03-26-2008 06:56 AM |
| green as they come | SILVERBACK | Industrial Hobbies (Support forum) | 6 | 09-25-2006 06:34 AM |
